Another 12v conversion question
skeeters65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Topic: Another 12v conversion question
    Posted: 11 Jan 2016 at 8:08pm
If I convert to 12v can I convert all 3 lights on my B or do I need to buy complete new light assembly's?
Thanks
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 8:16pm
Yes you can. 1156 bulbs in front. You might get by with that in the rear. I have done it to our WD45's and "C", but the "C" doesn't have the factory rear light. I forget the size bulb in the WD45 taillights.
Edited by Unit3 - 11 Jan 2016 at 8:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 8:26pm
Unit 3 is correct. You're probably better using a 199 bulb which has a heavier filiment for vibration being your B has no suspension. The bullet light bulb in 12V would be a T90 or the little higher CP T97.   HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 8:26pm
Is there just a grommet on the back of the light to put new wiring in? Or is it just a bulb swap???
Being lazy and don't want to run out to the garage.
Thanks
Edited by skeeters65 - 11 Jan 2016 at 8:27pm
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 8:55pm
They are bayonet base bulbs. You just push and twist to remove the bulb. Put the new one in push down and twist till it locks in place.
DanC911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 9:15pm
I changed the bulb in the rear of my B to LED.  I was able to find a red one in 6 volt on Superbrightleds.com.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 8:49am
Thanks
Lot of that going on right here today!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 9:11am
Thanks
Steve has replacement wires for the lights. Once the bulb is out, you can snip the old wire off in the back and pull it out by the little "bead" on the inside. Slide the new piece in and solder to your wiring.
