HD5B pressure plate |
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Topic: HD5B pressure platePosted: 02 Jan 2016 at 12:23am |
Swapping engines on the HD5 today and came across something I haven't seen before. The clutch fiber disc was in good shape, but the pressure plate is cracked. It has the Auburn cluth in it. Now I gotta find a new one.
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 02 Jan 2016 at 7:34am |
zimmerman tractor in versailles MO should have one but you may find a yard closer
truckerfarmer
Posted: 02 Jan 2016 at 9:29am |
Thanks for the link. Gonna do some checking around here first, but if I don't find one I will give them a call.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42280 |
Posted: 02 Jan 2016 at 9:42am |
Unsure if I still have parts - had one that was stripped of other parts and missing a few things - unsure if I still have the plate out of it . depending on your rush - can check later next week if
truckerfarmer
Posted: 02 Jan 2016 at 11:12pm |
Thanks Coke, that would be greatly appreciated! I was thinking about contacting you to see if you knew where I could find one. I may be looking for some steering clutch disc down the road.
gemdozer
Posted: 03 Jan 2016 at 6:47am |
I have a HD5 AUBURN pressure plate cluch with no crack,no lip but have a small spot rust heat
truckerfarmer
Posted: 03 Jan 2016 at 8:36am |
Thanks for the response guys! If you want, pm me, and we could discuss price and shipping.
truckerfarmer
Posted: 04 Jan 2016 at 10:16pm |
I found I could buy a new one from General Gear. When the wife heard that,she said 'Buy the new one! That way you won't have to work on it again!'. So I guess I will get the new one. You know the saying 'if momma ain't happy, ain't nobody happy'.
Thanks again for the offers anyway guys. |
Coke-in-MN
Posted: 04 Jan 2016 at 10:50pm |
I had found a couple pieces I needed for one clutch through MINNPAR but other parts I had to make .
For the throw out bearing the 2 blocks that go into the arms which move clutch - I had to machine them myself . The brass sleeve that goes into the throw out bearing collar I also machined from brass stock - one reason you want to leave clutch engaged and transmission in neutral when machine is setting and idling - that brass sleeve will wear if you dont.
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Posted: 05 Jan 2016 at 7:33am |
General Gear is the place to go.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025, |
truckerfarmer
Posted: 05 Jan 2016 at 9:17pm |
Yep! Ordered pressure plate and clutch disc this morning. Hopefully will be here Friday.
truckerfarmer
Posted: 14 Jan 2016 at 9:22pm |
Finally got around to rebuilding the clutch tonight. Was a piece of cake.
