Identify this PISTON
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Identify this PISTON
    Posted: 30 Dec 2015 at 5:16pm
                        This piston was removed from a D15 series I gasoline ....  Is it stock ? Is it Propane ? Is it aftermarket high compression ????  I do not have much experiance with rebuilds of D15 engines but have not seen one like this before.  Give me your thoughts and knowledge please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 5:38pm
Absolutely NOT stock or OEM !!    Power Crater bowl only is stock gas or LPG.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 5:47pm
Wow are you sure someone isn't messing with you? Looks like an international fire crater pistions do you by any chance have a farmall M there missing a pistion? At any rate I would say it is time to get some new pistions they should have a crater in them with a fairly step sides and a flat bottom not the full bowl like the wd motors had. There is a good thread over in the knowledge base section which shows what the allis chalmers power crater pistions look like.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 6:11pm
Looks like a M&W piston to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 7:05pm
If you look at the top left photo it has a MFG name CONFOR MATIC  but i have never heard of them.
eighty nine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eighty nine Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 7:08pm
It has Comfortmatic on the side. Google it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 7:10pm
Well....... i could do that but then look at all the fun we would be missing out on.  And the spelling is CONFOR MATIC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eighty nine Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 7:16pm
Ooops, Thanks for the spell check. Big smile
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 7:18pm
  i have heard of them ---took them out of a wd???--we nevr found any others had calls fo them --never fouund out who the supplier was--aftermarket something????  we had onne 20yrs.ago
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 8:00pm
Well if you do Google it you get one post in here from 2010 when someone asked about them and no one replied and there are a couple of posts from yesterday's tractors where it looks like of you get the number off the piston skirt someone Ober there might be able to set you up with rings.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 8:17pm
I have 2 sets of used Conformatic 4-1/8"  GE31X "dished" pistons for WD-45 or D-17.
I also have a single new Conformatic GE30X flat top piston for a WD.
They were from Sfterling Aluminum Products, a fairly well known company from the 40s and 50s.sterling aluminum products inc 1953 new conformatic pistons vintage ad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 8:36pm
Yep thats it !!!!!  And that's also why i ask question on here ......  You get the real answers with pictures.  :-))))
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 9:16pm
 I think tractor supply had conformatic pistons. I know i have overhauled wd's and 45's that had conformatic pistons but they had a dished piston.
turbocharged
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 6:35am
I can get u new pistons like this for the 149 engine .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 7:09am
I have seen many WD,WC B,C CA engines I have rebuilt with CONFOR MATIC flat pistons in them .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 9:21am
Hey Fred
Do these piston increase compression ???
Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 10:36am
Sent u a PM
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 11:31am
Since the design has a bump out on the top, it's POSSIBLE that the piston height/displacement could yield a different compression ratio, but more than likely, the engineers didn't go to any extreme measures to increase the CR.
The side effect to redesigning piston heads for higher CR, is increased shrouding of the valves, and disturbing the airflow. The internal-combustion secret society realizes that former isn't a really big deal... the piston shrouding valves only occurs when the slug is near TDC, and as the piston continues south, the shrouding moves away, but the complex shape of the top tends to create little pockets of stagnation, so the possible improvements and detractions are likely to cancel out, yielding more of an academic result than actual.
So unless there's really well-documented before-after performance change, I'd bet my buck that it was more patent-protected marketing magic than applied science.
That being said, one WILL find 'conforming pistons' to be more prevalent in air compressors than internal combustion engines... In larger scale scenarios, I saw the lid off a LeRoi (RoiLine) engine set up to be an engine-compressor 'unit', where the compressor slugs were conformal-fit to improve compressor output.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 12:44pm
Theory and education is always good .....
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 1:19pm
At top dead center using those pistons on a flush surface head the top ring has got to be way down in the sleeve.  Not that it could be a problem but would make a wide ring groove to remove. I had not seen that piston in any of my tear downs.
Edited by Dick L - 31 Dec 2015 at 1:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 1:25pm
Did u read FLAT PISTON . ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 1:54pm
An you expect an old man to read with understanding.Smile
Obviously I didn't. Wink
Looking at the picture of the subject piston I wondered.  Now I am still wondering.Smile
This page was generated in 0.093 seconds.
