190 axle bearing
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: 190 axle bearing
    Posted: 20 Dec 2015 at 7:29pm
anybody  know the hours  for flat rate replacing  an inside rear axle bearing on a 190 ?
thanks for the help.
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 7:26am
I don't know what flat rate is, but if bearing has not come apart it can be done without splitting or removing platform.     MACK
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 7:41am
Doesn't the bull gear have to be removed? The bearing goes in from the inside of the cavity doesn't it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 8:49am
i had a dealer replace the bearing , i thought it was the outside one, but yes it was the one on the inside. the bull gear must come out,  so   33 hours of labor later.   so i was wondering should it really take 33 hours, that is almost a full week of labor?  was wondering what allis said how long it should take ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 9:20am
As someone who is currently stripping down the back end of a 190 to restore, I can say there is a lot of time involved to get access to the rear axle (especially the right one). Fuel tank, operator's station, hydraulic linkages, fenders, console all need to be removed, then get reinstalled.  33 Hours seems pretty accurate for the whole job.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 3:30pm
Don't know total time but I do know 4-5 hours gets you to here.  This was 3 guys, but only 1 knew what to do.
Edited by Jordan(OH) - 22 Dec 2015 at 3:34pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 8:50pm
I have got to back up on what I said. I replaced the outer bearing by pushing axle out then lifted inner axle through drain hole to aline with inner bearing.
  Not my first mistake and won't be my last.
  Yes 33 hrs is way too much time. Have split one in 1 hour if every thing goes good, but has took longer when things went south.   MACK
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 8:26am
Just looked it up, 13.8 hours for both inside and outside bearings replacement for just one axle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 8:32am
That sounds pretty fair. I was thinking a couple 8 hr days. Of course, you have to have the proper equipment, which includes the correct pusher bolts to remove the rear wheel from the axle !!! if you don't have that tooling, you are at a disadvantage right off the bat. I have never seen a failed axle bearing on any 190 tractor, so it is indeed a rare thing.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 8:51am
Dad's 1965 190XT gasser failed an inside bearing. When the mechanic took it apart he said the out race was cracked. A couple months earlier I remember hitting a large hole with that tractor so hard I bounced and hit my head on the cab roof and hurt my neck. I was of course driving way to fast moving round bales. This was when I was a teenager. I always kinda figured that contributed to that particular axle bearing failure.
Wink
I am a Russian Bot
This page was generated in 0.217 seconds.
