CA question.
NateL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NateL Quote  Post ReplyReply Direct Link To This Post Topic: CA question.
    Posted: 04 Dec 2015 at 9:28pm
Is it possible to swap out a narrow front end to a wide front end on a CA?? Found a beautiful CA and need to know before throwing down the cash. Thanks.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2015 at 9:30pm
As long as you have the bolster with the wide front. The narrow front (two tires) ends do not have the same bolster as the wide fronts. They are different internally and make a difference.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote NateL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2015 at 10:01pm
Thanks AJ. How hard is it to find that part if I need one??
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2015 at 10:13pm
They out there but not the easiest thing to come across. Most people don't separate the two because you can't use one without the other. I have one that needs a little work but I'm not sure I'm ready to part with it.
Edited by AJ - 04 Dec 2015 at 10:14pm
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote NateL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2015 at 10:17pm
I've seen a lot of front ends listed, just didn't know if it would be an extra part to look for. Both of my other allis tractors have wide front ends so I've never done a swap.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2015 at 10:22pm
If it's an entire assembly it's just four large nuts. Two on each size and your steering rod connection. You do have to take your hood, grill, and radiator off of course. It's easy. If you need guidance let me know.
Can't fix stupid
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2015 at 5:30am
When I bought my CA it had a B arched front axle. If you just want a wide front and don't care about correct that's another option.
This page was generated in 0.085 seconds.
