Thin gasket supplier
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: Thin gasket supplier
    Posted: 20 Nov 2015 at 2:09pm
I need the really thin gasket paper for my B oil pump.  As I understand it, the paper gasket should be around 0.007 inches.  The thinnest paper I can find is 0.015 inches.  Any suggestions for suppliers of this paper?  Or can I use a paper bag or piece of paper?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2015 at 2:43pm
That's about 3 human hairs. I don't know if wax paper would hold under the heat or not. Parchment paper probably would. I'd think you'd want something that compresses a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2015 at 3:08pm
Yeah, I guess it will compress.  I'll try the 0.015 and see.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2015 at 3:22pm
You could always get the correct "already made" gasket from Agco. I can still get the hydraulic pump and PTO gear box gaskets for the WD/WD45 from them, so the oil pump gasket for the B/C/CA should be available, I would think. Rick
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2015 at 4:45pm
what happens if the gasket is thicker?
would blue glue hold?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2015 at 5:45pm
The end play was too great with the 0.015 inch gasket.  I got some 0.007 gasket paper and that worked within the specification for end play (0-001-0.003).  Thanks for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2015 at 5:54pm
I was wondering how thick (thin ??) an aluminum pop can is ? it'd compress a weee bit.
Jay
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2015 at 6:52pm
Will not hold prime!
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2015 at 8:46pm
Dad used to call it onion skin paper, not sure if that is a technical term or farm jargon?
Every B/C pump I have worked on had enough wear on the end of rotor and blades that the gasket is not needed for clearance. I flat file the case and cover only enough to remove burrs then bolt the cover on without a gasket. if it turns over with no stiffness take the cover off add a THIN bead of silicone bolt it back together and its ready to go.
Edited by Butch(OH) - 20 Nov 2015 at 8:47pm
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2015 at 10:06pm
When I bought a C I got several gasket kits and one had multiple thicknesses of gaskets for the oil pumps. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
This page was generated in 0.115 seconds.
