Hand Clutch fix
TennMatt1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TennMatt1 Quote  Post ReplyReply Direct Link To This Post Topic: Hand Clutch fix
    Posted: 02 Nov 2015 at 7:55pm
Anybody have a pic of a hand clutch on a wd 45 bolted together??? Mine is slipping and was told to just "bolt it together". What all is involved and what do I need? The way they talk its rather simple. Thanks for the input.
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2015 at 8:59pm
I don't have a picture but it is rather simple just split the tractor between the rear end and the housing after draining the fluid in the housing and there will be a pto drive gear bolted to the clutch and just get another gear like what i bolted to the clutch and and grind the lip off of both and bolt them together and put the tractor back together
Post Options Post Options   Thanks (0) Thanks(0)   Quote TennMatt1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2015 at 10:19pm
I am talking along the lines of from the top cover. Said I needed a right angle drill and just drill through the clutch itself and put bolts in it??? Just wondering if that's the case?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2015 at 10:39pm
If ya want to do it that way, forget the drill and get the welder out!
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2015 at 7:32am
Or you could just use one of these and forget about bolts.
Edited by Ken(MI) - 03 Nov 2015 at 7:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TennMatt1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2015 at 10:37am
Where you get one of those splined shafts?.. IM gonna replace the clutch and all first of the year so I don't wanna split the tractor right now,just don't have time to before tunica.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2015 at 10:51am
Kens piece is very nice and well built. CHeap enough also. Got one in the cabinet for future use
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2015 at 6:14am
Call me for one, 517 712-1896
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2015 at 8:34pm
if it was drilled and bolted int the right place could it be un bolted to go back to daily farm chores ? or would it ruin it ? my wd slips pulling on hard dirt but never seems to plowing or pulling impements   that spool looks like the best way for a dedicated puller
Post Options Post Options   Thanks (0) Thanks(0)   Quote TennMatt1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 11:06pm
Well I went to a pull today and it was on solid red claythat was like super glue!!!! I slipped bad in 4500 as the tractor just stopped at about the 250' mark....Time to do something.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2015 at 8:20pm
can't you just take some of the shims out an titen it up some would work a lot better
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 6:21am
Take top cover off and drill a 1/4 hole through all the plates with a magnet under drill bit. Place  bolt and nut through hole and go pull.   MACK
