Loader for a 7080 ????
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: Loader for a 7080 ????
    Posted: 09 May 2010 at 2:29pm
Did allis have a loader for the 7080s if so what model did they put on them?  Did they somewhat hold up for limited use?
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 2:33pm
wow, that's alot of hp for a loader tractor,not sure of an answer. can't recall ever seeing one on that big of a unit,at least not around here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 2:48pm
Just looking to move a little manure, snow, and maybe 10 pallets of seed a year. I'm not looking at utilizing the full power of the tractor.  That's just what works out best to put it on.
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 9:39pm
Allis Chalmers model 470
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 9:45pm
Aftermarket dual or westendorf should make something to  hold up but if you start using it to bulldoze trees it will make junk.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 8:24am
Buddie of mine has a woods on a 180hp case.  A very heavy well built unit.
Craig OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig OH Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 10:23am
we put this agco allis 884 loader on our 8010 we had to make some brackets but it works great.
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 1:27pm
I would guess the Westendorf TA46 loader like I have on my 7050 would bolt right on. It has been a good loader, but I don't use it to the extent a livestock producer does.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 5:15pm
 We have a bushhog loader on our 7020. For limited use like you said, it does OK. IMO a westendorf model is a little easier to put on and take off.. As you can see from redlines picture, you have to remove the loader before you can take the side panels off. Our bush hog loader is the same way. Just something to keep in mind..
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 9:15pm
We got a Westerndorf TA 46 on our FWA 8070.  The 46 is rated for that kind of power.  Quickie suppose to make a great loader too.   It is nice having a bigger tractor with a loader.  I can move a pallet with 60 bags of beans (3000 lbs) with no problem.  But with that kind of weight, I try to limit how far.  Here's their website.  http://www.loaders.com/default.aspx  They show the HP rating for each loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 9:20pm
I forgot to add that I can have the loader off in less than 5 minutes and probably alot quicker if I did it more often.  I can get the side shields off, but it is pretty tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 9:08pm
A TA46 will go on a FWA tractor? I might need to study my 9670 a little further. That would make a nice loader tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 8:41pm
The TA 46 is tight on there.  If I'd do it again, i would have went with a different series.  I have a picture of it, but to big a file to post.  I think the brackets are different between the series. You can contact westerdorf and they'll tell you exactly what you need.
