D 17 oil leak |
PeteiInAlbany
Topic: D 17 oil leakPosted: 12 Sep 2009 at 11:07pm |
I have an oil leak in the front and rear of my D 17 engine. I'm not sure if its the crank seals or just the oil pan gasket. Is there an easy way to tell for sure without splitting the whole tractor apart? Need input.
scott
Joined: 12 Sep 2009 Location: michigan Points: 2769 |
Posted: 13 Sep 2009 at 8:12am |
I had to pull my D-17 engine out and tear it apart last year. When I put the oil pan on I snugged the bolts but didnt want to squeeze out the gasket. Later, after discovering an oil leak, I figured out the pan bolts needed just a little more torque. Stopped the leak!
Joined: 11 Sep 2009 Location: illinois Points: 89171 |
Posted: 13 Sep 2009 at 8:30am |
take a wrench and try to turn the pan bolts 1/2 turn- all you can reach. see if that helps. on an older motor, quite often it is the seals. |
