bearing |
Randaleky
Joined: 17 Aug 2011 Location: belfry, ky. Points: 427 |
Topic: bearingPosted: 20 Oct 2015 at 8:45am |
anyone have bearings for fan shaft on allis hd4 dozer at reasonable price ? part # 245114
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Posted: 20 Oct 2015 at 9:45am |
isn't it a 2 bolt flange bearing ?
if my picture of shaft and support brackets are close the bearing bolted to upright . should be able to come up with something Allis Chalmers HD4 fan shaft bearing part # 245114 https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0CC8QFjADahUKEwi6z-2vpdHIAhVI7WMKHUs6Dtc&url=http%3A%2F%2Fstephensequipment.com%2Fdatabase.html&usg=AFQjCNEGR69xfBkB6bnLYvGVBLRWxB_cCg&sig2=4raGrr4a9KxJ41K_fHd2_w
Edited by Coke-in-MN - 20 Oct 2015 at 9:51am |
Randaleky
Posted: 20 Oct 2015 at 11:20am |
yes it is 2 bolt flange
Coke-in-MN
Posted: 20 Oct 2015 at 9:11pm |
any bearing house should be able to supply or measure shaft and might find at tractor supply or other farm service store .
If I knew the shaft size I probably have some in my parts bin - have 400/500 bearing I got when shop closed - rather than trash them I figured some day I could use them - have fixed spindles on several mowers , built few other things with them but 2 1/2 " 4 bolt flange bearings for air handlers I have not come up with use for YET .
Randaleky
Posted: 20 Oct 2015 at 9:50pm |
thanks coke. I have not pressed the old bearings off yet. I do have an hd4 loader for spare parts and I pulled the fan shaft out. seems that the bearings had been replaced recently. they are tight so I installed it into the dozer. I still want to find two bearings for spares. they don't seem to last long.
Joined: 11 Sep 2009 Location: illinois Points: 90878 |
Posted: 21 Oct 2015 at 7:23pm |
bearings are generic parts like bolts. Like COKE said, they sell the two bolt flange bearings at the local Farm Store, Bearing house, NAPA, etc....... you just have to measure the shaft size and bolt to bolt center line dimension.
Randaleky
Posted: 21 Oct 2015 at 8:34pm |
thanks , will do
Coke-in-MN
Posted: 22 Oct 2015 at 1:44pm |
8 years and never had problem with those bearings - sold machine and never replaced them in full time i had it .
if they have went out before - look to see if mounting is loose or bent causing load problems or shaft is bent - that will destroy bearings fast if vibration or flexing of the shaft .
