1947 AC WC attachements
dbaileyky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbaileyky Quote  Post ReplyReply Direct Link To This Post Topic: 1947 AC WC attachements
    Posted: 08 May 2010 at 6:11am
will the 47 AC WC pull a 2 or 3 plow? anyone have pictures or links to attachments for this unit?Also need info on recommended fluids
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 6:26am
A 2-14 plow will work fine in most soils. 80-90 gear lube is all you need except for the engine oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 6:39am
I have one of a styled WC and #2 plow but can't get it to upload.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbaileyky Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 6:58am
love the pic whats the diff between "styled" and "unstyled"
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 7:04am
The tractor pulling the disc is a styled WC 1938-1947. The WC pulling the All Crop 40 is unstyled,1933-1938. Same tractor, different sheet metal
JCinPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCinPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 7:19am
notice that the tires are on backwards on the WC pulling the disc.  Maybe swapped wheels from side to side to change tread width?  JCinPA
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 7:54am
Mine is 10 years older than yours but unless you've upgraded the motor 2-14 handles quite well.up
