WD Puller
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: WD Puller
    Posted: 30 Sep 2015 at 2:49pm
A few pictures of my puller
Charlie
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2015 at 3:15pm
looks good. Updated oiling system, and I like the hitch, simple and light. I had something similar in mind for my puller build.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2015 at 4:23pm
I'd like to get a shorter height control adjuster, I know I am below the axle but if the hitch broke I think it would still be way to high
Charlie
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2015 at 6:09pm
Why would you punish yourself with that seat ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2015 at 6:37pm
No issues. Just riding it down the track
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2015 at 7:14pm
Charlie,
 Very good looking WD puller. Has it been down the track yet? Those bigger tires should help against those green and red machines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2015 at 7:39pm
Yes I had it out a few times. Still fine tuning it and doing little things to it.
It pulls pretty good, just still getting used to the speed and rpm as I do 3.5 mph classes
I find it a lot of fun, not sure why, but it tickles my fancy
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 7:49pm
Charlie,
 The WD narrow front I have is right at 3500 lb. Is that where you are at with no weights?
I see you have removed a lot of items. But can you get down to 3000 lb?
I dont think they will let us run the 38 inch tires around here?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 8:36pm
3300 lbs is where it is now, puts me right at 3500 with me on it.
hit or miss on the 38's, some clubs say no, some it's OK.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 8:39pm
If you want more pics/ideas let me know
Charlie
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2015 at 5:26am
Figure out an adjuster/stop for the top like this. Works great...even better on orange.
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
