Allis dozer pics/ project |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Topic: Allis dozer pics/ projectPosted: 05 May 2010 at 7:06pm |
hi everyone, i have finally gotten My HD16 up and ready to work and i wanted to share some photos. I took some photos of my HD16 lined up with my dads HD10W and HD15. Thought it would make a good photo op. HD10W on the left in yellow(1947), HD15A, center, (1952), HD16A, right, (1959).
<img src ="www.donstractor.com/dz0.jpg">
<img src ="www.donstractor.com/dz1.jpg">
<img src ="www.donstractor.com/dz2.jpg">
<img src ="www.donstractor.com/dz3.jpg">
<img src ="www.donstractor.com/dz4.jpg">
<img src ="www.donstractor.com/dz5.jpg"> |
CAL(KS)
Posted: 05 May 2010 at 7:08pm |
silly syntax lol
Edited by CAL(KS) - 06 May 2010 at 11:54am |
CAL(KS)
Posted: 05 May 2010 at 7:16pm |
bah, im being hounded to get off computer. maby someone would be so kind as to fix my error. thanx for looking
Edited by CAL(KS) - 05 May 2010 at 7:16pm |
jminpa
Joined: 11 Sep 2009 Location: SouthEastern PA Points: 155 |
Posted: 05 May 2010 at 7:23pm |
jminpa
Posted: 05 May 2010 at 7:24pm |
Those are 3 big beasts you got there!!!
kip in cny
Joined: 29 Nov 2009 Location: Jordan NY Points: 538 |
Posted: 05 May 2010 at 7:44pm |
Nice toys I wish my sand box was bigger I do all I can just to use my HD3
160 CA 920diesel 5020 HD-3
CAL(KS)
Posted: 06 May 2010 at 12:10pm |
got a big job this weekend. going to work the 15 and 16 side by side. gonna be fun. ill try to post some pics.
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25326 |
Posted: 06 May 2010 at 3:44pm |
looks like you have a couple eager operators there, too!
PJsomd
Joined: 17 Jan 2010 Location: Southern MD Points: 43 |
Posted: 06 May 2010 at 4:39pm |
very impressive
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4556 |
Posted: 07 May 2010 at 3:53pm |
Nice machines. Way bigger than my H-3
CAL(KS)
Posted: 15 May 2010 at 11:20am |
well i was not able to get any pictures as my camera is now having issues accepting memory cards, however my dad and i each put 15 hours or our respective machines. Our job was to remove some trees and push a lot of dirt back on to a 1/2 mile of sunken road so that the water would flow to the ditches again instead of down the road. We accomplished it without much incident, and had fun. My 16 did a great job and the motor is leak free and didnt blow up so i must have done my overhaul right, lol. We did discover that dad's hd15 needed a new clutch as we were hesitent to tighten it any more and was slipping a little, so he was easy on it. Weve already got it torn down, it just needs a driven disc, the rest looks very good and is in much better shape than when i replaced my HD16 clutch.
happy pushing everyone....
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4948 |
Posted: 24 May 2010 at 10:31pm |
Nice looking machines Cal.Do the blades want to naturally want to dig in by the weight alone.Have never seen a cable operated blade working and wondered how they did.I would imagine hyd.would be better.Just wondering.
CTuckerNWIL
Posted: 25 May 2010 at 8:15am |
Pat, cable blades can drop a lot faster. LOL
Rick of HopeIN
Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1329 |
Posted: 25 May 2010 at 6:44pm |
hydraulics eventually offered many advantages including speed. Also 6 way blades, etc. They told me the cable machines were more precise back in the day and it took a while for hydraulics to be reasonably reliable in the dirt.
CAL(KS)
Posted: 31 May 2010 at 9:40am |
A cable blade will go into the ground quite well unless the ground is very hard or cutting bits are worn off. The bits on either end of the blade should be longer (protrued farther down) than the center cutting edge. These will suck the blade into the ground unless the ground is very hard, or your dealing with a lot of rock. My cutting bits are far from new but have performed well. Cable blades will most often lift higher than hydraulic blades which is very nice for tree removal. Also, alot of dozers were still equiped with cable blades in order to also use for pulling scrapers even after hydraulics became popular. and yes early hydraulics were slow and often leaky because of seal technology and dirt.
BobsAc
Joined: 14 Oct 2010 Location: Lakeside, CA Points: 19 |
Posted: 14 Oct 2010 at 6:31pm |
Great looking spread, thanks for the post!!!!!!!!!!!!!
acwdwcman
Joined: 16 Oct 2010 Location: palmyra, il Points: 1075 |
Posted: 20 Oct 2010 at 9:54pm |
wanting to get a ac crawler sometime.that will wait though im only 13 and have 2 tractors. wd and wc unstylled |
Jeff(WD45-SATX-TN)
Joined: 13 Sep 2009 Location: Sewanee, TN Points: 443 |
Posted: 20 Oct 2010 at 9:59pm |
Hey Cal, sweet line up of big crawlers there. You can do some serious earth moving for sure!
Any idea where those mosters originated? Are they local to your area?
Jeff
1954 WD45 NF "Iron Tater"
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34403 |
Posted: 24 Oct 2010 at 4:00pm |
Been trying to talk a gent out of a HD11 in Salem Mo for over two years, sits in the brush but he says he may try to use it yet again. As far as I can tell it has not moved in ten years, offered good money but he won't budge.
MarkBon
Posted: 26 Nov 2010 at 2:44am |
Whoa! That's quite a machinery!
