11-B Repower |
Lazyts
Topic: 11-B RepowerPosted: 10 Sep 2015 at 10:45am |
Currently working on fitting an N7 combine engine to an HD11. Will try to post pics later...
jorstad brothers
Posted: 10 Sep 2015 at 10:46am |
can wait. this is something i want to do. let me know how it works.
remember plunder than burn
Steve allis dozer
Silver Level Access
Joined: 10 Apr 2011 Location: Australia Points: 232 |
Posted: 17 Sep 2015 at 9:57pm |
How is the re power project going ? were there many up grades to the 685 engine from the 11000 series?
I am looking forward to seeing some pics Regards steve
Lazyts
Posted: 17 Sep 2015 at 10:47pm |
Lazyts
Posted: 17 Sep 2015 at 10:57pm |
685 engine is inter-cooled, has different oil filters and oil cooler, upgraded injection pump and injectors. So far I have:
-swapped damper, fan drive and water pump pulley -installed oil cooler for torque converter -swapped rear housing and flywheel -removed electric sensors and plugged holes I thought this was a good idea because combines in this area are relatively low houred. This one showed 3500 or so on the meter. Exhaust manifold is badly cracked though, does not look salvageable, was a common problem on N7 I've heard. I was going to rebuild the 11000 engine, but a friend of mine knew about this combine, and wanted some parts from it, so I bought the combine, drove it to his place, we pulled the engine, and he bought the rest. |
HD6 Merv
Joined: 03 Aug 2010 Location: New Zealand Points: 501 |
Posted: 18 Sep 2015 at 5:17am |
cheers for posting Trev
Is a few of us interested in this thread
tits tyres and tracks
they all cost you money |
Lazyts
Posted: 18 Sep 2015 at 8:10pm |
Lazyts
Posted: 18 Sep 2015 at 8:30pm |
Steve allis dozer
Silver Level Access
Posted: 19 Sep 2015 at 8:53am |
the 685 won't have the two oil pumps and twin sump for working in steep country ?
Lazyts
Posted: 19 Sep 2015 at 7:42pm |
Right- just has single sump, only good for 25 degrees or so. Dual pumps are supposed to be good for 45 degrees. I might swap out oil pan and pump, not sure yet- likely this tractor will live out its days in the flat lands.
Steve allis dozer
Silver Level Access
Posted: 20 Sep 2015 at 2:10am |
The extra pump would be handy when digging dams .
Thats a cool project I bet she will have plenty of power , thanks for posting !!
Lazyts
Posted: 28 Sep 2015 at 9:07pm |
Decided I had better go ahead with oil pump swap- turns out the crankshaft gear is different on the 685, so had to exchange oil pump drive gears as well. Also had to bend torque converter oil lines to clear spin on filters on engine, and will have to do some rearranging to get the fit between turbo and air filter. These little things take time.
Lazyts
Posted: 08 Oct 2015 at 8:46pm |
Lazyts
Posted: 08 Oct 2015 at 8:49pm |
Lazyts
Posted: 08 Oct 2015 at 8:59pm |
Lazyts
Posted: 08 Oct 2015 at 9:04pm |
Tried 'er out today- feels and sounds exactly like any other 11-B. If you couldn't see the mods, and ran another side by side with it, you wouldn't know which tractor had the 685 and which had the original 11000. Took longer than I thought, but all in all a success, I think. Plus it just looks cool.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9004 |
Posted: 09 Oct 2015 at 8:16am |
My brother had a71 or 72 11B.It came with the P pump.Nice tractor.Would out work the D6C's. Blade and push arms weren't as good as Cat's in my opinion but HEY!!
BCPaul
Joined: 24 Sep 2015 Location: Northern BC Points: 21 |
Posted: 09 Oct 2015 at 6:34pm |
Nice job, looks good
Lazyts
Posted: 09 Oct 2015 at 8:44pm |
Yeah, you don't see too many 11s that haven't had the push arms broken at one time or another. The thing is, they went from 100 to 150 horsepower, added nearly 10000 pounds, and never changed the push arms- something had to give.
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 10 Oct 2015 at 3:56am |
that's a good looker!
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Posted: 10 Oct 2015 at 4:53am |
Lazyts
Interesting that the FA 10 was what Fiat thought an HD 11 should have looked like Our 10 is 100hp and all there, 10B was wound up 100rpm and 110 and I have seen that 10C was 130 with a different engine. Don't know if they went more. But I'd be surprised if the push arms on our 10 straight blade would have been worried up to around 200. A dozer fixing neighbour made some interesting comments on the size of the track frame diagonal brace too. |
Lazyts
Posted: 10 Oct 2015 at 9:25am |
11-B was replaced by Fiat 14-C in 1977. Not sure how they would compare working side by side.
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 12 Oct 2015 at 11:16am |
Sure looks like it will do the job. Hope you are satisfied.
Allis Express participant |
Lazyts
Posted: 13 Oct 2015 at 10:43pm |
Maybe we'll have to put one in a standard shift tractor! Then again, might be a bad idea...
