720 Hydraulic Lines |
ShaunE
Bronze Level Access
Topic: 720 Hydraulic LinesPosted: 13 Sep 2015 at 9:44am |
I have recently added the final two front hydraulic lines thanks to D-17Dave. However the lines I added were from a Simplicity Powermax. That being said, I need the short extensions that bring the couplers at that downward angle out the front bracket. The ones I need are for the LEFT side as you are facing the front of the tractor. I believe they are going to be longer than the ones I have on the right side as the lines that go to the LEFT side are located higher in front of the battery.
I hope that makes sense. Thanks Shaun
Edited by ShaunE - 13 Sep 2015 at 10:05am |
mnoonan-NEWI
Joined: 11 Sep 2009 Location: Marinette, WI Points: 739 |
Posted: 13 Sep 2015 at 9:54am |
Shaun,
I have the 4 factory hydraulic lines on my 720 and have a couple of close up pictures I could email you. Mike
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
ShaunE
Bronze Level Access
Posted: 13 Sep 2015 at 10:01am |
That would be great.
Thanks
PM Sent
Edited by ShaunE - 13 Sep 2015 at 10:49am |
ShaunE
Bronze Level Access
Posted: 13 Sep 2015 at 11:51am |
After seeing Mikes pictures, I see the lines going to the left have a slight bend in them to compensate for the height difference. So the short extensions are all the same length.
hopefully they will be easier to come by. Thanks Mike
Steve in NJ
Posted: 15 Sep 2015 at 6:42am |
I'll take a look at mine because I installed new fittings up front, and I don't remember what I changed on mine. I might be able to fix ya up with the fittings like I used. Let me take a look tonight. If I remember correctly, my fittings both come out at the same length side by side of one another. One isn't higher or out farther than the other that I can remember...
Steve@B&B |
ShaunE
Bronze Level Access
Posted: 15 Sep 2015 at 7:30am |
Thanks Steve.
