Firestone Verses Good Year |
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Sep 2015 at 11:34am |
Firestone Field & Road. Good Year Dyna Torque II. Same size, 13-6x24. On 11 inch rim, liquid Ballast Loaded. Equal 5 psi tire pressure on a #4000 puller.
Which one pulls better? I have a choice either way |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22089 |
Firestones.....Armstrongs......BF Goodrich.......all other brands.....Goodyear last choice.
blue924.9 ![]() Orange Level ![]() ![]() Joined: 22 Mar 2013 Location: George Iowa Points: 1089 |
ive got a good year on one side of the wd and a bg goodrich on the other lol, the good year does mounds better than the goodrich but that doesnt mean either one is good in the grand scheme of things i guess
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
patrickmull ![]() Orange Level ![]() ![]() Joined: 11 Jan 2011 Location: Casey IL Points: 893 |
i pull a set of cut goodyear dyna torque and do pretty good
acd21man ![]() Orange Level ![]() ![]() Joined: 07 Jan 2010 Location: tn Points: 831 |
they are only good for a year lol jk i like firestone radials . radials always hook up better but its more money
The cleat pattern on the Firestone is quite a bit different than the COODYEAR tread. These like new Goodyears I have were kabota front takeoffs when the owner wanted turf tires instead. Got them with tubes for $200 the pair.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8368 |
In my pulling years, it was Armstrong's, in the 5 mph class, they always done great on the 200
DSpears N IL ![]() Silver Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Rockford,Ill Points: 415 |
You are running the rims that had these tires on them when I got them! DeWayne |
What are you weighted up to Dwayne?
I was going to use your yellow jap rims with the my Goodyears on a C that I was building but that project got stalled until I move more used parts to pay for it. |
Hi Ken!
I was weighted up for 3500 lbs in the 1st photo and 3700 lbs in the 2nd. We also pull a 3200 lbs class. DeWayne
our classes are set up 3000, 3500, 4000 and so on. With the 13-6 24s my CA don't get hooked up traction wise until the #4000 class. That is with all added weight to the rear.
Ken
I got a 1st in 3200 class, a 3rd in 3500 class, and 3rd in the 3700 class on fresh black dirt today DeWayne |
I have a pull coming up next weekend. hope to pull my CA 3 times if they let me pull farm stock like they do sometimes. Next big pull after is the LA State Fair two day Antique Tractor Pull in Shreveport
dgerth ![]() Bronze Level ![]() Joined: 27 Nov 2012 Location: NC Wash Points: 174 |
Ya'll work the snot outta those little guys! We only run 2.5K and 3k with ours. Can't run with the WD's and Olivers in the 3.5k class even at 3mph.
dan
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
I had great luck with old Co-op tires. Forget the name they gave them. Lots of space between the bars. At least as good as firestone field & road. Used them on my D17 the first year I pulled it but by the end of the year the dry rot had taken it's toll so I made the mistake of putting new Armstrong long bar/short bar tires on. Worst tires I ever pulled with but this tractor I also used to farm 80 acres with and no extra money to buy another set of tires. I learned to choose my tracks and stay on very sticky wet clay or wet black dirt. Did well as long as I was choosey. Made lots of Deere folks angry with my rusty, trusty D17.
Wink I am a Russian Bot |
