720 engine swap
Alex (wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex (wi) Quote  Post ReplyReply Direct Link To This Post Topic: 720 engine swap
    Posted: 02 Sep 2015 at 8:03pm
Anyone put a diesel in one of these? Any ideas or thoughts would be appreciated.
Alex
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2015 at 10:45pm
depends if you want to streach the frame somone on here had some with turbocharged diesels they looked real sharp if there is one that fitts without frame or clutch mods i would like to see because that is what i would like in my 616
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2015 at 2:23pm
A B/S Vanguard or Kohler Command would make a nice swap I would think. Don't know how much work it would be though...
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2015 at 5:14pm
My 720 has been re-powered with a gas 23 hp B/S engine, it works very well.
Dusty
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2015 at 6:10am
Fellow here in manchester but a 3 cylinder kubota in his.  I lot of things did not work correctly without some serious reengineering
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 4:19pm
23hp briggs vanguard fits excellant minimal work to change it over
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 4:41pm
How does the Briggs compare to Honda repower? Tracy
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 6:58pm
Might try to contact Larry Karg at orangespectacular.com. He has done some innovative engine swaps and extensions on this tractor size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 9:45am
tracy ,   havent done a honda but my honda rep did supply us with catalogs for allthe stub shaft s and muffler options  havent compared general engine dimensions but the briggs is minimal clearance all the way around
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 10:17am
I would like to put a Honda in one of mine. Thanks Tracy
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 7:08pm
If the frame is extended, what about the hood?
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 10:44pm
Larry Karge's 720 was at Hickory Corners approx ten years ago; it looked professional. That was before I became interested in 720's, now wish I had pursued details.
