hd-5g
jturano11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jturano11 Quote  Post ReplyReply Direct Link To This Post Topic: hd-5g
    Posted: 02 May 2010 at 8:25am
I found that my trans oil has water in it, I got under the machine to look for a drain plug, it doesn't look like I have access to the bottom of the transmission. anyone know how I can drain it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 9:46am
trany and ring gear share common resivore , should be plug just behind trany on rear case . this area refills through plug on top of trany. Plug on side of trany is level indicator.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 1:15pm
 You should have a transmission plate protector but you should have a hole on for
the drain plug .
