hd-5g |
jturano11
Joined: 26 Mar 2010 Location: Pennsylvania Points: 34 |
Topic: hd-5gPosted: 02 May 2010 at 8:25am |
I found that my trans oil has water in it, I got under the machine to look for a drain plug, it doesn't look like I have access to the bottom of the transmission. anyone know how I can drain it?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 02 May 2010 at 9:46am |
trany and ring gear share common resivore , should be plug just behind trany on rear case . this area refills through plug on top of trany. Plug on side of trany is level indicator.
gemdozer
Posted: 02 May 2010 at 1:15pm |
You should have a transmission plate protector but you should have a hole on for
the drain plug .
