Sickle bar mower part. |
aforeman80 ![]() Bronze Level ![]() Joined: 31 Jul 2015 Location: Corydon, IN Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Jul 2015 at 10:48am |
My father bought this snap coupler mower a few months ago and while he was using it a few weeks ago what looks like a pitman arm broke. I am hoping that I can find this part for him as he really enjoys using it. I will attach a few pictures of the mower and the broken part to hopefully find parts.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53955 |
Twin wheel drive arm. Bolts to blade. I'm guessing a #7 rear mount mower. Others will chime in, if I am wrong. Hard part to find, unfortunately...
Edited by DiyDave - 31 Jul 2015 at 6:11pm |
Yes. I have been told that it is a number 7 twin wheel mower, but I didn't know if anyone on here might have a part or be able to point me in the right direction of one. I want to thank all of you in advance for any and all help.
Matt (Jordan,MN) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Jordan, MN Points: 3799 |
I have one of those that I will sell. Send me a pm if your still looking. Thanks matt
Owner of Matt Scott LLC
Specializing in NOS and used Allis Chalmers tractor & implement parts & liturature and Magneto Repair http://www.mattscottllc.com/ |
DennisA (IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ridott IL. Points: 2064 |
The bearings are replaceable. Yes you do have a #7 mower. Hope you fine all the parts you need.
Edited by DennisA (IL) - 07 Aug 2015 at 10:36pm |
Thanks & God Bless
Dennis |
Ok. I need to know if I need to grind out the rivets to get the bearings out or if they come as a set. I just want to get his mower going again. Thank you for all of your help.
Did some more checking for you. Looks like the part is sold as an assembly. Here is the part number I have found 70803978. Your mower is one of the early #7 mowers. Your best bet would be an AGCO dealer and hope for NOS parts. If you like I could contact my dealer to see if they could find one. Let me know.
Thanks & God Bless
Dennis |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22824 |
It looks to me like the side the nut goes on, has a snap ring. If it is, remove that and push on the head of the bolt to get the bearing out.
Spelt Farmer ![]() Bronze Level ![]() ![]() Joined: 10 Jun 2013 Location: Ohio Points: 91 |
My gut feeling is that you will have to grind off the rivets to get the bearing out.
-Aaron |
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2259 |
Like CTucker says it certainly "looks" like there is a snap ring holding that bearing.
On the other hand, like Aaron says it may be necessary to grind the rivets. In any even, this is the first "two piece" connecting rod I've seen and there must be a reason that it is sold as a complete assembly including the bearing. The parts book lists a bearing as being available for the one-piece rod only. My question....are the bearings bad enough they need replacing. Those expensive little bearings on the small end of the rods look to be in good shape.
Just curious, are those the same goofy aircraft bearings Allis used on the 80 series mowers? |
It this point you really have other option than to remove the rivets. The newer style connecting rods will not work with out replacing the flywheel as well.
Thanks & God Bless
Dennis |
Aaron,
The bearings on the small end of the rod are those unusual "KP" aircraft bearings you speak of. Not so easy to come by locally but are available from "Aircraft Spruce & Specialty Co". I bought a pair of the KP-8s in '09 for $33.00 a pop. I believe the small bearing used on the two piece rod (Ser.# below 10601), is the KP-6 which has an OS Dia. of 1.4375". The small bearing used on #7 mowers Ser. #10601 and up (and the 80 & 82 series) is the KP-8 which has an OS Dia. of 1.6875". If the bearings on the large end of the two piece rod are the same as those in the one piece rods, they are common bearings available at any auto parts store. The last ones I bought back in '99 were #SPE 6304 at $16.99 each.
I called my dealer and you can still get a couple that are NOS, but Agco no longer supplies them. Dealer is A.C. McCarteny's 815-248-2161. If you want you better jump on them before someone else does.
Thanks & God Bless
Dennis |
mdefelice91171 ![]() Orange Level ![]() ![]() Joined: 26 Jun 2014 Location: Brooksville, FL Points: 258 |
Hi guys, just found this post while looking for info on my No. 7 as well. I've got it all hooked up and am trying to determine which parts I am missing. Turns out I need the ENTIRE swath board assembly and outer shoe. Basically my bar has nothing on the outside end so I'm looking for all the parts. Also, I am looking for the bar support angle and all the parts to go with it. Sorry I don't have a source for bearings, but I am new to this machine also. If anyone has and is willing to sell me the parts I need, please email or PM. Michael.c.defelice@gmail.com 727-422-3360. Thanks!
