Resurfacing 180 flywheel
Fellenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Topic: Resurfacing 180 flywheel
    Posted: 26 Apr 2010 at 7:53am
Hello,
We're redoing the clutch on our 180 and need to resurface the flywheel. I need the spec'd dimension for the distance between the surface the pressure plate contacts and the ledge where the clutch bolts to the flywheel.
Measuring off the far edge where it doesn't appear worn t looks like the dimension is around 1.440" can anyone confirm or deny this is right?
Thanks,
Erik
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 7:59am
185G/D is; Dimension "A"= 1.437 +/-.01, Dimension "B"= 0.688 +/- .01. Maximum flywheel may be machined is 0.062 in. Dimension "B" will determine if flywheel has been machined before. If "B" is less than given dimension, then it was surfaced already
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 8:06am
Thanks for the reply! Where is dimension "B" measured?
Thanks,
Erik
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 8:16am
looking down on flywheel "B" is the "lower" step down. When machininh the flywheel dimension "A" remains the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 8:20am
Thanks!
