Pull reminder!
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Topic: Pull reminder!
    Posted: 03 Jul 2015 at 11:16am
Antique classes have 4 mph speed limit after the barrier. Barrier will be positioned according to track conditions, 20" hitch, 20% over factory high rpm, cut tires allowed, must use factory engine block, (no 6 cyl.in 4 cyl chassis) no alcohol fuel.
Open, no speed limit, any tire , 20" hitch, wheelie bars and kill switch mandatory, any engine, 3000rpm max without scatter blanket and shields, gas, diesel, methanol...
Give me a shout with questions...
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2015 at 9:25pm
I am going to and come this year. What is best way from Chattanooga?
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2015 at 9:39am
I really dont know... lots of work been done on hwy 64. If its 4 lane most of the way I would say its the shortest. Let me ask around, I have some truck driving buddies. ..
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 7:46am
Sam T-GA
Everyone claims take 24 up to the mountain and take 64 west to Pulaski will be the quickest, and best route.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2015 at 2:39pm
Is 64 on top of Mt eagle or 1st exit north?
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2015 at 7:49am
Not sure Sam, I THINK it is on top, only done it a few times a long time ago. Unless you already going to be in Chattanooga may want to look at comin through Rome, up through Huntsville, up I65.
I will try to find out, to answer your question ....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2015 at 8:26am
Thanks for the info, but I'm not going to make it. I got to much hay on the ground. Tried to get finish but didn't. Hope you have a good pull.
sandman2234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandman2234 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2015 at 5:56pm
Hwy 64 is after the mountain, going north. Pretty sure it is the first exit after you hit flat ground again. Guess it is a little late to mention that...
  David from jax
A proud member of the Allis Express movement!
               Northeast Florida
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2015 at 8:31am
Hate you had to miss it, had almost 100 hooks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2015 at 5:59pm
Sorry I missed it, sounds like you had a good pull. When is your next pull in Tn?
This page was generated in 0.184 seconds.
