AC G wiring question
tmays View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tmays Quote  Post ReplyReply Direct Link To This Post Topic: AC G wiring question
    Posted: 05 Jul 2015 at 12:45pm
Wiring diagram shows generator armature terminal to cutout. Also shows discharge side of ammeter to cutout. Does armature go to unmarked post or batt post on cutout? 1948 G wiring back to original. Thanks
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2015 at 2:11pm
Ammeter connections depend on battery polarity. I presume positive ground. The the + post on the ammeter goes to the battery, usually at the stud on the starter switch. The negative ammeter post gets the wires from the lights, ignition, and bat terminal on the cutout.Generator armature goes to the other terminal on the cutout.
If negative ground the connections to the ammeter are opposite. + terminal gets the generator and loads, - terminal goes to the battery.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tmays Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2015 at 2:46pm
Thanks, Gerald! Just what I needed to know! :-)
This page was generated in 0.108 seconds.
