Crunchy Final drive
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Topic: Crunchy Final drive
    Posted: 24 Jun 2015 at 10:06pm
Here's a bad day:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2015 at 10:14pm
Looks like the HD4 I had went through 1 bull gear and 2 pinion gears -
also outboard bearings on axles - 3 axles - and then decided next owner could fix when broke as it ran when sold .
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 1:52am
Preload on the tapered roller bearings right up there Trev?
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 2:52am
FWIW
A Fiat Allis comment
So far haven't been in here with our FA 10 but a wrecker I talked to mentioned he had one with 12000 hours on and the finals hadn't been apart.
I hope, but various scars says ours has had a rough life earlier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 10:03am
what machine is that on ?
Had to have case welded up on my FD5 as outboard axle bearing ate into bearing cut and destroyed the casting , had steel insert welded into case to hold that bearing ,
 On my HD4 both sides of machine had the cases fixed with steel insert.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 11:06am
It is an older dry steer HD11.  I'm pretty sure the bearings have never been looked at before, full of grit now.  At least it is someone else's tractor, and I have a donor.  A win-win for me.  I wonder if it didn't break because of the track adjusters in a round about way- I can see that the track was trying to come off the sprocket, there are gouges in the links, several sprocket teeth are chipped, and one sprocket tooth is broken off entirely.  Tracks were way loose.
