200 hyd pto
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Topic: 200 hyd pto
    Posted: 10 Jun 2015 at 7:59am
any help appreciated--bought 200 last summer-- went to bale 2nd cutting hay, PTO runs enough to make 3/4th of 1 bale then just fades away. baler stops running. Parked tractor till this spring. Local mechanic put new clutch parts in PTO last month also checked pressures with flow meter and pressure gauge.   Went to bale hay last night--same thing-- stopped to let 1st bale tie and the PTO just stopped. Any suggestions before I take it back to him. THANK YOU   Tom
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2015 at 8:14am
When the PTO stops will the power steering and power director still work OK?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2015 at 8:35am
Don Yes they still work. I've only put maybe 1 hour on the tractor since I've had it. I've thought the PD might be slow to engauge but that might just be me.   the steering is ok
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2015 at 8:45am
Steering is priority flow, it will go away last.   PD and PTO are non priority flow, it sounds like the pump flow is going away when it gets warmed up real good.  Flow rater might not show low flow unless oil is real warm.  PD slow to engage could be indicator of low pressure/flow.   I would take a hard look at the hyd pump, its not real hard to work on and wear plates and seals wont break the bank.  Ya gotta do sumpthin, its no good the way it is. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2015 at 9:37am
skipwelte I pulled the site up as the phone was ringing, Brett the guy that worked on the tractor was on the line he ask the same thing you did. Got to be in the pump or some valve somewhere. I read off to him your and Dons response. Another question--this thing jumps out of 3rd gear could filings get into the hydraulic system from that? I have a shop manual but it is so mixed up, pages out of order-- pictures black, it is impossiable to use. Will drop it back off to him Friday or Sat night. Thanks MUCH   tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2015 at 2:50pm
If the hydraulic pump is weak will he steering be loose when traveling down the road? Must keep turning the wheel back and forth to keep it going in a straight line--some time the steering wheel will almost rotate 360 degrease. The tie rods and rest of the mechanical parts in the front end are not worn out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2015 at 9:42pm
Your steering issue is not related to the hydraulic pump.  The steering cylinder needs new seals.  That is the cause of constant steering wheel turning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2015 at 1:22pm
thanks for the replies fellows-- much appreciated
