185
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Topic: 185
    Posted: 03 Jun 2015 at 10:47pm
How much power will the 185's gears hold up to for pulling?
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2015 at 8:38am
I would say the torque tube shaft is the weakest link and it will hold 1000 hp.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2015 at 10:24am
That's what I thought but reading some people said the rear end wont hold up.
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2015 at 12:12pm
When you get to a certain level of HP, you are running road gear, which is direct drive. The standard 2-pinion differential needs to be "needled" on the pinion shaft gears and have bronze washers behind the side gears (from a WD45) when you get over 500 HP. I also believe in a bronze rub block behind the ring gear (like a semi-truck axle) to minimize spreading of the ring gear to pinion gear under load. With that being laid out there, it is all stock components 100% until you get to requiring gear speeds faster than road gear. 1200 HP at 6700 lbs with 24.5 x 32 tires happens all the time in my neighborhood without troubles (yet).
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2015 at 12:27pm
That's good to know. I was afraid of braking something, only thinking about going to 100 hp.
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2015 at 12:41pm
If you are actually going to put 100 HP thru it AND pull a 4-bottom moldboard plow, you'd better raise the oil level in the transmission (overfill) an inch or so. You also better have a dual wheel on the left side and fluid in the rear tires. The differential can be destroyed in short order on a moldboard plow with extra HP. When the left tire is out there scratching away for traction, the poor differential gears are going for a ride !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2015 at 1:34pm
I only have 3 acres so no plowing here. Besides in Western Washington the only thing I can grow is rain clouds. My 185 has the head off and so far I need pistons, just haven't made up my mind on which way to go (stock or more power).
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
This page was generated in 0.127 seconds.
