185 |
one54dodgetruck
Joined: 25 Jul 2011 Location: Chehalis, wa Points: 399 |
Topic: 185Posted: 03 Jun 2015 at 10:47pm |
How much power will the 185's gears hold up to for pulling?
2 WDs
B B112 D14 D15 shuttle 180 185 7040 Hd7w D14 D15 185 7040 pd |
MACK
Posted: 04 Jun 2015 at 8:38am |
I would say the torque tube shaft is the weakest link and it will hold 1000 hp. MACK
one54dodgetruck
Posted: 04 Jun 2015 at 10:24am |
That's what I thought but reading some people said the rear end wont hold up.
2 WDs
Thanks(1)
Posted: 04 Jun 2015 at 12:12pm |
When you get to a certain level of HP, you are running road gear, which is direct drive. The standard 2-pinion differential needs to be "needled" on the pinion shaft gears and have bronze washers behind the side gears (from a WD45) when you get over 500 HP. I also believe in a bronze rub block behind the ring gear (like a semi-truck axle) to minimize spreading of the ring gear to pinion gear under load. With that being laid out there, it is all stock components 100% until you get to requiring gear speeds faster than road gear. 1200 HP at 6700 lbs with 24.5 x 32 tires happens all the time in my neighborhood without troubles (yet).
one54dodgetruck
Posted: 04 Jun 2015 at 12:27pm |
That's good to know. I was afraid of braking something, only thinking about going to 100 hp.
2 WDs
Posted: 04 Jun 2015 at 12:41pm |
If you are actually going to put 100 HP thru it AND pull a 4-bottom moldboard plow, you'd better raise the oil level in the transmission (overfill) an inch or so. You also better have a dual wheel on the left side and fluid in the rear tires. The differential can be destroyed in short order on a moldboard plow with extra HP. When the left tire is out there scratching away for traction, the poor differential gears are going for a ride !!!
one54dodgetruck
Posted: 04 Jun 2015 at 1:34pm |
I only have 3 acres so no plowing here. Besides in Western Washington the only thing I can grow is rain clouds. My 185 has the head off and so far I need pistons, just haven't made up my mind on which way to go (stock or more power).
2 WDs
