Allis Chalmers Road Grader |
seedub930
Topic: Allis Chalmers Road GraderPosted: 30 May 2015 at 5:05pm |
I have a Allis Chalmers road grader, serial number 145-242. I believe it was manufactured from 1952-1955. It is a 4 cylinder diesel. The fuel pump needs rebuilt and I am unable to find parts for it. Any thoughts on where to find parts and/or another fuel pump.
ILGLEANER
Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Posted: 30 May 2015 at 5:15pm |
Send Ed a PM on this site he runs a pump shop. He could help you out.
IG |
ILGLEANER
Posted: 30 May 2015 at 5:16pm |
He goes by injpumpEd. Forgot to say that.
IG |
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 30 May 2015 at 9:09pm |
Capital Injection in Holt Summit, Mo will fix it
seedub930
Posted: 30 May 2015 at 10:35pm |
Thanks ILGleaner. I will do that. JoeO... I sent the pump to Capital City Diesel in Holts Summit, they work on all my diesel pump issues. They said the pump is obsolete and parts are no longer available.
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Posted: 31 May 2015 at 2:38am |
As a runner of the bigger brother (AC Forty Five) I'll be interested in what you find.
TIA |
gemdozer
Posted: 31 May 2015 at 6:55am |
the 145 should have a 344 motor and maybe I could help for the injection pump
JoeO(CMO)
Posted: 31 May 2015 at 7:58am |
Bummer!! |
Ian Beale
Posted: 31 May 2015 at 4:10pm |
seedub930
Earlier on this site I posted an enquiry on a place that advertises heads etc for American Bosch pumps including PSB's but got no feedback. Topic: AMBAC PSB Injection pumps Posted: 25 May 2015 at 2:16am I haven't done any more exploring as yet but you might be interested to try. Edited by Ian Beale - 31 May 2015 at 4:12pm |
Mactractor
Joined: 20 Jun 2011 Location: New Zealand Points: 652 |
Posted: 31 May 2015 at 8:08pm |
Has been talk of rebuild and parts possibilities for the PSB`s on the wheeled tractor engines (Buda 230 and AC 262) over on farm equipment, but no glimmers of hope discussed for the PSB`s on construction equipment engines |
gemdozer
Posted: 01 Jun 2015 at 4:06pm |
I have a rebuilt AMERICAN BOSCH fuel injection pump PSB 4A 90EH4081--4348761
and a used one PSB 4A 100EH5307 B1--4338334
Sappypappy
Joined: 01 Jun 2015 Location: United States Points: 1 |
Posted: 01 Jun 2015 at 5:15pm |
HI, I own a Model D motor grader and I have 2 issues. Antifreeze is in my oil and I am not sure how it got in. 2nd I have heard that the WD-45 carburetor is a nice one to switch to. Please let me know what the oil and the carb options are, thanks.
Joined: 11 Sep 2009 Location: illinois Points: 90863 |
Posted: 01 Jun 2015 at 9:04pm |
pappy, the most common points for Allis gas engines to leak antifreeze into the oil are thru freeze plugs in the head ( under the rocker arm), or around the wet cylinder sleeves with O-rings into the block.... Best advice is to take off the valve cover and look at the plugs under the rocker arm for pin holes or evidence of antifreeze..... If you see nothing, then pull the oil drain plug and let the oil all out. Fill radiator and it may drip into the pan and out the drain hole... If you see that, then take the oil pan off and inspect closer.. If it is the liner O-rings, you can replace or use a block sealer to plug the leak. I have had good luck with BARS COPPER gasket sealer... I think it is #1109.
Posted: 01 Jun 2015 at 9:06pm |
