Ca headlight mounting?
Lincoln View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lincoln Quote  Post ReplyReply Direct Link To This Post Topic: Ca headlight mounting?
    Posted: 13 Apr 2010 at 7:35pm
I have a 1951 CA that has been redone. I do not know where the headlights mount. If someone can show a picture that would be great.
thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 8:32pm
There should be a half inch or so hole in the hood and front shroud where they overlap, maybe 4 inches down from the top of the hood. The lights mount in these holes. Here is a picture of somebodies CA with lights.
Edited by CTuckerNWIL - 13 Apr 2010 at 8:36pm
RoyR (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoyR (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 8:33pm
There should be a hole on each side where the hood and the radiator shroud meet.  The lights have a mounting stud that fastens in the hole.
Roy
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 8:50pm
The holes thru hood and front shroud are oversized in that one spot to accept a light at each side.   Same setup as used on the B and C tractors.
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 9:38pm
The original lights have a wire that runs thru the center of the stud that mounts the light to the tractor. The 1/2 inch hole should be a threaded insert to screw the headlight into the radiator shrould. Cal in Ct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 12:14pm
Yep, the lights thread into the radiator shroud and there are a couple holes with rubber grommits in them for the wires to pass through.
