trans seal..
bmartin55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Topic: trans seal..
    Posted: 21 Apr 2015 at 5:33pm
I have a seal leaking ..when I put in oil in trans it goes into my power directory. .how hard is this to fix ..and parts number I need.
Dr allis can u help..
Thanks.bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2015 at 5:34pm
Sorry it is a d17 puller..
thanks.bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2015 at 9:33pm
Did you remove the PTO shaft?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2015 at 10:20pm
Yes pto is removed..all lighten up..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2015 at 10:29pm
Well, you have to shove something back into the front PTO shaft hole, the oil just runs thru the seals when the shaft is removed. A great big cork or plug or a short chunk of shafting the same diameter as the PTO shaft you removed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2015 at 10:35pm
Ok I can do that .
The guy I got it from did it..
I can fix..
Thanks Dr allis..
Bob
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2015 at 8:19am
i just let mine flow back and forth may have to add a couple times and recheck both compartments only use mine to pull with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2015 at 9:03pm
That's all I do.is pull ..
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2015 at 9:41pm
If you keep the level at trans. level you are loosing hp because pd is running in oil. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2015 at 6:45am
That's right. The Power Director oil level can be and is lower than the transmission oil level. If anything you can run the trans an inch or so overfull to protect the differential. The PD clutch overfull just wastes HP.
