410&416 slipping in all gears |
Ross D.
Silver Level Joined: 02 Sep 2013 Location: Erin, Ont. Points: 338 |
Posted: 20 Mar 2015 at 8:40am |
Good morning. I have two 400 series tractors. The 410 has a 42 in. mower and is a shuttle shift. The 416 has a 48 in. mower and is also a shuttle shift. I use both units to cut our lawns. The rear tiller fits both and is sometimes used. I have rebuilt both tractors. The problem is with both units. I put new AGCO 'V' belts on both forward and reverse. I have tried to adjust all the necessary areas as outlined by the original service manuals. Both machines continue to slip in all gears, forward and reverse. I have limped with both machines, by using belt dressing to help eliminate the problem. This 'bandage' does not work well and I can normally limp to the shop for more belt dressing. Could the pulleys be worn enough to allow this irritating slippage? Do I need a wider belt to take up this slippage? 'HELP', please. Thank you. Ross. Sorry for the size of the picture.
Dgrader
Orange Level Joined: 17 Jan 2015 Location: Newton,IL Points: 1037 |
Have you greased the shuttle clutch? On the rear end on right side ya pop the cap off and fill with grease.
Ya cain't fix stupid.
Ross D.
Hi. No, I have not opened this cap yet. I will try to get to these units later today and have a look. Have you had any experience with this type of slippage? Ross.
Dgrader
No I haven't. I just suggested greasing the clutch because you said it was slipping in all the gears. It doesn't have a zerk, like I said ya gotta pry off the cap and push grease in there. It's something that gets overlooked a lot.
Ross D.
Good morning. Dgrader, thank you for your suggestion. I was able to get the cap pried off the 410. It appears to be an access to some assembly. It is completely dry at that point. There is no reference, in the lubrication section of the operators manual, for any oil or grease to be checked at this area. Do I have to disassemble this assembly? It will have to be moved into the shop in a week or two. The snow will probably take another week to disappear. Ross.
Dgrader
No Ross, you don't have to disassemble. Just work some grease into it by hand and just roll the clutch around by hand and see if that helps.
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3333 |
try 00grease it is semi fliud mower shops should have it in quuart jugs oregon #54-029 it is what we use in all of the trans axles that donot require 80-90
EdW
Bronze Level Joined: 02 Oct 2009 Location: central IL Points: 79 |
When you have the cap off that assembly check the large but that holds it together. It can work loose causing the same simptoms
EdW
Toscani NE SD
Orange Level Joined: 21 Jan 2011 Location: Milbank S.D. Points: 369 |
I have a 416 that slips also, im gonna look at this when it warms up around here,i also have to keep a tarp strap on shifter or it will pop out of gear
Ross D.
If there was a problem with the driven assembly, why would the belt dressing cause the forward/reverse situation to operate the tractor better? When it starts to slip again, I just added more belt dressing and it was 'good' until it wore off again? Any ideas? The inside of the pulleys, and the belts are 'caked' with this old dressing. I want to order new belts, but I need to verify what the actual problem is. Could the pulleys be worn out and I need to order a different belt size?
farmtoybuilder
Orange Level Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1453 |
I would say incorrect length or width of belts. You could also try a heavier or new spring on it. Maybe tension is in-correct! As it should kill engine or spin the tires.
