426/516 question |
studer automotive ![]() Orange Level Access ![]() Joined: 10 Sep 2013 Location: jeromesville,oh Points: 562 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Mar 2015 at 9:08pm |
Was reading the post on the IH 466
Repower. Why didn't a-c use the 516 In the larger tractors? (8070, 4w305, 7080 etc.etc.) just Wondering |
a-c 185-d y/r cab turbo soon
99 f-250 7.3 4x4 86 mustang5.0 owned since 8/93 |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
They'll tell you it was too old and heavy but IMO that engine was a better engine and got great fuel economy and was easy to start comparatively.
Edited by Lonn - 16 Mar 2015 at 7:06am |
Wink I am a Russian Bot |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21906 |
Too expensive......too heavy......too slow speed.........tooooo much torque for the existing transmission.
I think my question would be is why did AC develop a tractor to use that engine? I think I know the answer though which is the first doc gave above. Really the answer to me would have been to upgrade fuel and cam and cooling and starting issues and beef up the crank on the 426, although we have never broken a crank in any of ours.
Edited by Lonn - 16 Mar 2015 at 8:11am |
Technology has now given us engines that are very similar in size to the old 426 and are now 530 cubes or even more. The overall length is the same. The weight is close to the same. The fuel efficiency is better and they sure don't smoke like older engines. I'm referring to the DT466/DT530......Cummins C-8.3 and now newer 8.9 version. The use of that big old heavy A-C 516 just wasn't in the cards. A modern engine of that size/weight would now be 700 plus cubes....C12/C13.
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11753 |
Correct me if I'm wrong, but the 516 was a derivative of the old Buda 844 engine. Just too expensive, large and heavy to compete.
No. 844 and 731 were the same block family. The 516 was in-between the 426 and 844.
Pete from IL ![]() Silver Level ![]() Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
What was the 516 engine used in? I don't think I ever saw one.
grinder220 ![]() Orange Level ![]() Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2370 |
Jwmac7060 ![]() Orange Level ![]() ![]() Joined: 04 Jan 2014 Location: Indiana Points: 929 |
Wasn't the 8550 and 4w305 powered by the 516....better question is why didn't AC sub out the engines in the larger tractors...Can you imagine how popular those tractors would have been with a Cummins in them
No they had the 731 in them. I just repowered my 8550 with the 844 engine. I personally have never been impressed with a Cummins. Not in a truck, not in a tractor and not in a semi. If I hadn't found an 844 allis I would have gone with a 3406 cat.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8356 |
They had that in mind with the Kamotsu ; but you have to remember they brought these tractors out in very bad AG price times , nobody was buying new stuff and id say Allis lost their a** on most of them
Grinder I'll respectfully disagree...Ive run both in semis and I'll take the Cummins fuel efficiency over the cat anyday...we have 2 850 verstiles with the 855 Cummins in them and they are pulling SOBs...if I can't pull it at 1200 rpms...you ain't gonna pull it...Cat is almost like a Deere 466...Gotta wind it out to take off..no low end torque..imo
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5097 |
I'd take an 855 Cummins over a 3406 any day as well. The most popular application for the 516 I'd say is the HD11.
ILGLEANER ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
I would take a hot blonde over an 855 or 3406
AC would have been a lot better off if they would have used the 516 in the N6 . I was told that the 516 would hold up to constant rims. But when tested in tractors, wouldn't hold up to the up and down of the rpms in a tractor usage. I would still liked for them to have tried it. IG |
Mactractor ![]() Orange Level Access ![]() ![]() Joined: 20 Jun 2011 Location: New Zealand Points: 652 |
With you there Ed. I got 20,000 hours on a 855 Big Cam 4 and it aint been apart. I remember the misery the 3406 caused me.
The 516 would have made a great wheeled tractor engine if gearing was matched to the lower revs, and driveline was solid enough for the torque. As for weight, why would you want a lighter engine, then hang thousands of pounds of ballast on the tractor? As with any engine, with a torque converter behind them, they get through fuel alright, but in direct drive crawlers they are very easy on fuel for their power |
BPM75 ![]() Orange Level ![]() ![]() Joined: 11 Jun 2011 Location: Greenup IL Points: 1050 |
I'm not quite sure what cat you have driven but 3406 cats were always more of a low end eng usually done its best pulling from 12-1600 I've driven countless trucks in last 20 year's as a heavy duty truck mech and never had a cat that had to be wound out to take off as you say. This is especially true with newer electronic engines. The only cats that didn't have a lot of low end in my opinion is the 3176 which became the C10 and C12. Edited by BPM75 - 16 Mar 2015 at 10:08pm |
59 D17 gas nf, 66 XT 190, 69 220.
The 3176 (629 cubes)became the C-10......the 3196 (731 cubes)became the C-12.
Hate to sound dumb but I never heard of a 3196, I do know other than bore and stroke there is no physical difference between C-10 and C-12. We used to have a bunch of Frt. Condos with C12 and several single axle flds with C10s I overhauled a bunch of them. I'd much rather work on them than the ISX we have now in the IH ProStars lol.
3196 was never in a truck that I am aware of. Only construction and AG. C-10-11-12-13 are all the same block/head configuration and are different bores & strokes....not much different, but different.
That's probably why I've never seen one, never worked on construction equipment much, and my ag exp is with CaseIH and what's been on our farm.
Dkienzle ![]() Bronze Level ![]() Joined: 22 Feb 2013 Location: Central IA Points: 192 |
Bingo! I'm guessing he hasn't been around a 3406E model. Before the old man sold the trucks he had a w9 with a 3406E model set at 550 and then a t6 with a isx Cummins set at 525. He was not impressed with the Cummins. It never got the fuel milage it was supposed to and didn't have the power he thought it should have. And that it never really ran as smooth as the cat did. I love our 8.3 Cummins in our 7080 but as far as big truck engines go cat ruled the roost here.
Had a W-9 with a 3406e in it...it was much better than the Mechanical 3406...Now have a 389 with an Isx set at 525 and I'm getting 7.3 mpg....never got better than 6.6 with the old cat
Dad could never get much above 6.8 with the Cummins. Bout the same with the cat. 6.6 or so. Cat was a 2000 year model. Cummins was an 07. He was just never really impressed with it.
