1979 715B Oil Translation
NEK715 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEK715 Quote  Post ReplyReply Direct Link To This Post Topic: 1979 715B Oil Translation
    Posted: 26 Feb 2015 at 5:59am
Hello,
My user manual calls for ESN-M 2C 53-A Axle Oil for the rear end of my 715B Backhoe loader. What does that translate to in modern day oil? Some say regular gear oil, witch I could believe since it is just a beefed up version on a truck rear end.
But I just wanted to make sure
They must have not used SAE 90 for a reason, since it was available at the time and the 4 speed manual gear box calls for that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEK715 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 6:17am
looks like Valvoline Unitrac is what I should be using per the link below.
http://www.valvoline.com/pdf/hd_unitrac.pdf
The part number is VV813 in a 5 gallon bucket. Looks like they sell it at Oriley's auto parts.
http://www.oreillyauto.com/site/c/detail/VAL0/813/N0419.oap?ck=Search_N0419_-1_-1&pt=N0419&ppt=C0139
Any idea where I can get it cheaper? ... I hate Orileys..
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEK715 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 6:25am
Dose vv813 sound corrct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 9:10am
You answered your own question of oil - Universal tractor hyd fluid meeting below specs. As the rear uses wet brakes the fluids are the same as used in many other applications where a gear oil and hyd fluid are use for lube. Farm supply stores should have it as well as Sam's club did carry it . Case / IH hy-tran fluid meets the specs also
Meets or exceeds the following older specifications(Where appropriate viscosity grade applies): John Deere JDM J20A, J20B, J14B, & JD 303; Ford New Holland ESN-M2C134-C, ESN-M2C134B, ESN-M2C134A, ESNM2C86B, ESN-M2C53A, ESN-M2C48-B&C; Massey Ferguson M-1129-A, M-1127-B, M-1127-A, M-1110; Case B-6(HYTRAN®), MS-1206(PTF), MS-1210, MS-1205, MS-1204/JIC-185, JIC-144, JIC-143, B-5; White Farm(Oliver) Q-1802(Type 55 Fluid), Q-1766B(Universal HTF), Q-1722(White MP Tractor Oil), Q-1705(Universal HTF); Agco(Allis) 257541, 246634; Versatile Hydraulic /Gear Fluid Spec 24M, Spec 23M; Hesston Fiat AF-87; Oliver Q-1802(Type 55), Allison C-3 Fluid; Caterpillar TO-2; Allis Chalmers PF 821XL; API GL-4;
This page was generated in 0.813 seconds.
