616 vs 620/720 engine
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: 616 vs 620/720 engine
    Posted: 10 Nov 2014 at 9:01am
What is differant? Just carb? Manifold the same?
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2014 at 1:07pm
I only had a 616 for a short time when I bought a 720 and 616 from the same guy.  Sold the 616 to finance fixing up the 720.  These are what I remember as differences between the 616 to the 620/720.
The carb is differenct as you said.  The air cleaner is different.  Of course the horsepower is different.  I'm guessing that there may be more differences (besides decals and what I mentioned) but I do not know any other than what I listed.
Den
Own 5 720 garden tractors with associated equipment,1 620 garden tractor, 4 wheel 20
2-5015, 5020 and associated equipment and 2 electric forklifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2014 at 3:02pm
is the air cleaner different simply due to the different carb size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2014 at 3:05pm
good somebody post an up close of the air cleaner on the cckb and also the carb without the cleaner?
Thanks!
David
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2014 at 5:42pm
616 CCKA:
620/720 CKB:
IB (restoring), MF GC1705, MF 2705E
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2014 at 6:02pm
Good deal looks like all cckb Manifold are the same
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2014 at 8:02pm
The CCKA carb mounts to top of manifold. The CCKB mounts to side of manifold. HTH Tracy
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2014 at 9:45pm
On the 620/720, what is the cylindrical black part between the
manifold, carb and air cleaner. Maybe a crankcase scavenger gizmo?
Then look at the complex 90 degree formed hose connecting the air cleaner and intake side of the carb. Can that be purchased new?
And last, is the air cleaner a little on the small side?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2014 at 9:51pm
Yes and yes. Hold onto your billfold! Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2014 at 4:48am
here is my nos engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2014 at 4:49am
here's my part's engine for things like the flywheel and oil pan and ignition
Dan(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2015 at 1:40am
I need the RH engine cover for my AC 720 with the Onan 19.5 HP CCBK engine. Please e-mail me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2015 at 3:44pm
talking this cover Dan? you didn't give me an email
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2015 at 6:48pm
I think that is the cover I need. I will send you a photo of my engine in a couple of days. Please e-mail me the price and your e-mail address and phone number to dan.monaghan@yahoo.com
My engine number is Onan CCKB-MS / 2733J 12V Serial No. 0874746485
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2015 at 8:33am
Some of the wiring is a little different also. Routed and color coded differently on some circuitry between the 616 and 620/720. Wiring and color coding the same on the 620/720. Seems like the 616 is the morphidite of the three.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2015 at 2:19pm
my boss [the wife] said i could order parts main and rod brgs. for my ccka in the 616 but what makes the rated horse power diff between the ccka cckb i know i asked once before its not just the carb intake aand heaveyer flywheel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2015 at 8:03pm
I think the RPM's were increased also. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2015 at 2:32pm
the gizmo isjust a crankcase breather probley the easest piece to find used
