WD engine compression
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Topic: WD engine compression
    Posted: 20 Mar 2010 at 6:51pm
What is the normal expected compression on a WD engine.  If that is too hard to answer, what would the compression be on a standard rebuilt WD engine.  Thanks, Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2010 at 7:45pm
The original 201 gas engine had a compression ratio of 5.75:1; that would result in approx 90 psi compression. However, after market rebuild kits that have higher compression ratio pistons have been around for a long time. 100-120 would be a tight one. If all cylinders are fairly equal in compression (within 5psi of each other), 80-100 should run smoothly.
