Wd engine build help |
Free37
Joined: 02 Jun 2014 Location: Knoxville tn Points: 10 |
Topic: Wd engine build helpPosted: 02 Jun 2014 at 8:12am |
I'm build a wd with the 45 crank and it is stroked 5/8 with farmall c rods I need to figure out what pistons to us I have 4.125 sleeves. Thanks
Posted: 02 Jun 2014 at 10:39pm |
With the crankshaft installed in the block and one connecting rod installed on the crankshaft, measure down from the top deck as to where the piston pin center is located at TDC. Then, you need to decide what compression ratio you want and calculate from there.
Free37
Posted: 03 Jun 2014 at 8:11am |
What is a good compression ratio for 110 octane
bigcountry48
Posted: 03 Jun 2014 at 8:34am |
11:1 would probably be the best choice, not too much stress on the motor and it will run that octane.
Edited by bigcountry48 - 03 Jun 2014 at 8:34am |
Free37
Posted: 03 Jun 2014 at 3:07pm |
Does anybody have an ideal for pistons on this engine
Fields
Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
Posted: 03 Jun 2014 at 9:25pm |
Is a farmall c rod 8 inch center to center. You can figure a cr. Needed with pistons. Deck high is like 12.625 inches. Take half your stroke. The rod length and the piston pin higth . Remember your allis head is flat. So any combustion chamber will be in the piston or the space between the piston and the head. Not for sure on the head gasket thickness but felpro one is ? .043 ?.
Free37
Posted: 03 Jun 2014 at 9:28pm |
The rod is 7.250 center to center
Fields
Posted: 03 Jun 2014 at 9:43pm |
I got bored. So here is a Ih 8 cylinder or 4 cylinder truck engine piston that might work. http://www.summitracing.com/parts/slp-h996cp/overview/
