Allis Chalmers HD5
bulldog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bulldog Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers HD5
    Posted: 01 May 2014 at 11:51am
A friend has a HD 5 with low oil pressure,all bearings have been renewed, is there a oil pressure adjustment ? what is the correct pressure, its 15 psi now
Thanks
Martyn
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2014 at 12:15pm
Was it 15 psi before the new bearings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bulldog Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2014 at 12:30pm
Its alway been low , what is the correct pressure ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bulldog Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2014 at 12:33pm
He has recently got the machine and had someone to work on it.15 psi seems low to me. I wondered if there was a pressure relief valve or any adjustmen to increase presure ? or perhaps the oil pump is at fault.He has no manual to work to.
Thanks
Martyn
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2014 at 12:55pm
new bearings will not make up for worn cam bearings or worn crank - to much clearance and low oil pressure results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2014 at 1:11pm
Had the same problem. We replaced the cam & balance shaft bearings and had the bearing surfaces on the shaft welded up. It fixed the problem.
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2014 at 1:56pm
When I bought my 5G - the seller told me he had just replaced the rod and main bearings but had light oil in it and pressure was low - well I changed oil and still low so i replaced the oil pump - still low - but operable - pressure dropped at idle but would come up to 30 PSI at 1800 RPM or so .
 Couple years later I developed a oil leak at rear main - tore down and found crank was worn - had ground and new bearings as well as new pistons and sleeves , oil pressure came up 45 PSI .
 Couple years later replaced the head as one valve seat burnt and came loose . Also had small cracks to injector sleeve (a normal thing I found out later) and engine runs great yet 15 years later .
 Dang just counting I have owned the machine for over 35 years now - and it still runs.
Edited by Coke-in-MN - 01 May 2014 at 1:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2014 at 2:03pm
I have a photocopy of HD5 manual I will sell if your friend wants one
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2014 at 10:52pm
Make sure it is not putting diesel in the crankcase.Detroits are known to have the fuel lines on top of the head start leaking around the fitting,but do not over tighten as that will make it leak more.They used to be cheap and just change them if there was any sign of oil being thinned with diesel.Don't know how parts are as DD as a company has had many owners in the last 20 years.And greenies don't like the 2 cycle diesel.I have seen this several times and much cheaper than new bearings.Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bulldog Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2014 at 11:01am
Saw the machine today as it shared a lowboy with my D4 enroute to a vintage show, seems to run OK. Will have a closer look at the machine on Saturday.
Thanks for your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2014 at 11:59am
Yes if you do any injector work or anything in that top end WATCH the injector lines . 15 inch pounds torque on line nut . double flare fitting and they will crack just behind flare thinning oil and dropping pressure .
chumduffy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chumduffy Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2014 at 3:35pm
I would buy your manual Coke, just let me know how much you need for it and where to send you a check. Thanks', Chum..
This page was generated in 0.207 seconds.
