Hard starting ACC-50
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Topic: Hard starting ACC-50
    Posted: 02 Apr 2014 at 8:43am
I have an ACC-50 forklift, and it is really cold blooded.   I run down the battery and almost all of the jumper box before it starts.   Exhaust smells of propane, so fuel seems sufficient.  Once warm, it runs great all day.   seems like a choke would help, but none available.  When I get a chance, I am going to try the hair dryer in the air intake trick.  Any other suggestions?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2014 at 10:31am
Can't help you but we have the same model and it starts with no problem.
Vaporizer or spark???
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2014 at 11:32am
The lap converter/ vaporizer is themost likely problem. They fill up with Tar and that stiffens the diaphragm until the engine warms up.i think that will either have a beam system or impco either way they're not too much money that's where I'd start
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2014 at 3:34pm
Our lift use to be the same way, its an ACC30, but an old mechanic told me how to cure it, ours has a small 4 cylinder renault engine, 12V system, but the ignition, which I am told is common is only 6v, if you have an external resistor, they take a wire and go from the start side of the starter up to the coil,bypassing the resistor it gives the coil a true 12 v on start, so the spark is much hotter to make it fire quicker, and once you let go of the key, it drops back down to the 6V. Now ours starts great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2014 at 10:23pm
I just thought of another possibility if it has an electric LP lock off you may need to install a crank bypass. Usually the electric lock off is operated by and oil pressure switch if the engine doesn't have Oil pressure it won't turn the fuel on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 7:24am
Thanks guys, I will explore each of these items and report back.  Sorry for the late acknowledgement, somebody at corporate headquarters decided I hadn't worked out of town enough.  Think I'll ask "the Chicken" to have a talk with him!
