boring out engine block
Tractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractor Quote  Post ReplyReply Direct Link To This Post Topic: boring out engine block
    Posted: 25 Mar 2014 at 8:55pm
i want to get the engine bored out on my allis chalmers b-12 engine since they don't make the oversized pistons for it any more and i was wondering if anyone else had there engine bored out and what measurements i would need to send it to a machine shop  to bore it out to a 14hp?
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 10:12pm
all you haft to do is tell the shop man what you want an he should know what piston size you need to get 14 horse or more. he can order you a rod an the right piston an head gasket'' good luck. hope it works good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractor Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2014 at 8:19am
Any idea of how much it would cost?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2014 at 11:58pm
call around an check on a new piston an rod with rings cost ask the shop man what hes got to have to bore 1 hole an add it up an you should be close to cost a little larger piston cant be but a few bucks more if any
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2014 at 6:13pm
Machining prices and parts prices vary widely. Do you want to use B&S parts or aftermarket? My local guy gets $30 to bore a 1 cyl, $35 to turn a single cyl crankshaft, $25 to do the valves and lap them int, $10 to surface the head, while some large shops might not want to even touch a job like this. Since your taking so much more out of the bore in this case, there may be additional cost.
