hd6 fuel pump
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Topic: hd6 fuel pump
    Posted: 31 Jan 2014 at 11:41am
I got a friend of mine with a hd6 he took the injector pump off to go get tested at a diesel shop all I know he said they lost it or don't have it ? anyway will it has the top injectors 6000 engine I know were theres a 344 buda side injector hd6 is does anyone know if that pump will work on the 6000 engine
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2014 at 12:50pm
interesting question michale. Am curious myself. Both are bosch psb pumps. Both are different part numbers, but wether they just update I don't know. I would have exploded at the fuel shop. You don,t 'lose' fuel pumps; and if you did best you replace it.
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2014 at 1:27pm
I have the PSB pump off my donor HD7G, if he ends up needing one and it would work as a core to build I would consider selling it as a core. It was open for a extended period before I got the tractor.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2014 at 5:45pm
I had to look around this area with our AC 45 grader.
Not sure on the 344, but they played tunes on the 516's.  There are 9 and 10mm plungers, and there are different injection timings.  9mm's were 32 degrees, 10mm 28.
I got this from a HD 11 parts book and service manual, but don't have access to them any more.
Jensales have an Allis  tech manual on the PSB pumps that might help.
Edited by Ian Beale - 31 Jan 2014 at 5:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2014 at 5:46pm
Should add that that manual HD 11 service manual had instructions for changing timing marks on the flywheel too.
(edited)
Edited by Ian Beale - 31 Jan 2014 at 5:48pm
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2014 at 6:01am
I have 3 injection pump for 344 with different number and one is rebuilt with # 4348762
                                  gemdozer@hotmail.com
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2014 at 9:22am
My HD6 book says # 4348762 is for engines prior to 6-10368
# 4349851 is for engines after however the injector plumbing ilustrated with these pumps is for the HD344 engine.
My HD7G book says #74354230 for the 6000 & 7000 engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2014 at 9:05pm
He said the fuel shop he took the pump to kelp putting him off saying they were backed up and trying to find parts for it he said next thing he knew they were closed up and someone told him the pump wasent left in the building and the owner pulled the over 30 day terms on him sounds like they sold his pump to me or tore it up and didnt want to replace it no wonder they went out of business that same place charged my dad 140.00 dollar a piece to rebuild injectors for a hd6g in 1984 he about had a stroke
rnugen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rnugen Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 11:06am
I need an injection pump for an Hd6E. does anyone have a good core or a pump I could purchase. I have 3 of these dozers and one is almost brand-new and now has a bad injection pump.
Thanks
Ron
208-305-6995
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 10:23am
I have  a injection pump PSB4A 100G-5811A3--4354233
Post Options Post Options   Thanks (0) Thanks(0)   Quote rnugen Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 10:26am
Thanks for the replay. Do you know if it will fit and work on an HD6E? I don't know very much about the numbers on the injection pumps.
Thanks
Ron
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 6:04pm
This pump should fitt  and have a part number on the head HD6800A and this pump was on motor with bad motor HD6
Post Options Post Options   Thanks (0) Thanks(0)   Quote rnugen Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 6:15pm
How much do you want for it? I am interested.   I found one in California that is supposed to good for $500. Let me know, I need one.
Thanks
Ron 208-305-6995 is my phone. You can text on that number too.
Nugenrw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nugenrw Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2020 at 3:49pm
I finally got back to the posts. Can you let me know if you are getting these posts. I sent 2 replies and haven't heard back. I would like to buy the injection pump from you.Thanks
Ron.
