190 XT fuel question |
farmboycitygirl
Topic: 190 XT fuel questionPosted: 18 Feb 2010 at 8:16am |
I noticed a few weeks ago when running my 190 the engine would speed up and slow down. I am thinking it is 'lack of fuel'. I was going to replace the fuel filter and put a electric fuel pump on it.
What do you all think?
Lonn
Posted: 18 Feb 2010 at 8:42am |
You in cold weather? Could be gelling or plugged filters. try that first. My guess would be the inj pump seal is coming apart.
Wink I am a Russian Bot |
Gary (sw Wis.)
Silver Level Access
Joined: 12 Sep 2009 Location: S.W. Wis. Points: 222 |
Posted: 18 Feb 2010 at 8:49am |
Valve leaving the fuel tank could be partially plugged.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
kinghunter
Joined: 30 Jan 2010 Location: Kansas/Missouri Points: 408 |
Posted: 18 Feb 2010 at 9:26am |
i had that same problem and had to clean settling bulbs and get flow going again as everything was clogged up once clean it run like new again.
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 18 Feb 2010 at 10:51am |
It is a sign of restricted fuel flow or a weak supply pump inside the injector pump.
Mike NEIN
Joined: 15 Jan 2010 Location: Rome City, IN Points: 405 |
Posted: 18 Feb 2010 at 11:42am |
The rubber seals in the hand primer pump will do it too.
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 18 Feb 2010 at 12:11pm |
Or the inertial ring in the governor section in the pump is coming apart and the little bits are restricting the return outlet on the pump. You might take the return fitting off the pump and start the engine and watch for little black bits coming out with the fuel. |
Pete from IL
Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
Posted: 18 Feb 2010 at 10:01pm |
You really don't need an electric fuel pump on a 190. The first thing you do is shut off both fuel shutoff valves under the tank, (on top of sediment bowls). Take off sediment bowls, then open the shutoff valves one at a time and see if the fuel flows out freely.If the fuel comes out very slowly or not at all you have a blockage where the fuel comes out of the tank and into the sediment bowl. Open the shutoff valve on the bowl that is restricted and take an air nozzle and blow air in the hole where the fuel should be coming out. You then should have fuel flowing out freely. Look in the tank and check for debris . If the tank has a lot of crud in it you may have to have the tank cleaned out . The next place to look is the fuel filter, lines , return line, then inj. pump.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8767 |
Posted: 19 Feb 2010 at 10:00pm |
I vote for the governor ring.If its' been YEARS since pump was down,that's probably it.Do what Brian says and "inspect" return fuel.
