Idiot lights
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Topic: Idiot lights
    Posted: 11 Feb 2010 at 1:42pm
OT: My sons Kubota's oil light is coming on and staying on until the tractor is speeded up cnsiderably.  According to him this is a change and he was wondering if it could be the oil pump or the sensor or the light.  I said yes.  He said the tractor sounds fine as always and has never used any oil.  It's a 3 cy diesel.  Is there any testing I can do before he just changes the sensor and or light.  Hate to drop the pan but if we  need to we can haul it to my shop and tackle the job. Any suggestions before we do that.  THX, Jim
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 1:56pm
Put a Tee where the pressure sender is and put a back mounted mechanical gauge on it as well as the idiot light
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 1:57pm
I'd get a pressure guage and check the pressure.  I don't know the spec's but your dealer should.  There is a chance that the sending unit is bad and needs more pressure to turn the light out (hopefully).  Also does it take more RPM to turn out the light when the engine is warm, if so that is and indication of low oil pressure due to something out of clearance .  I don't know much about kobuta, but get a pressure check done.  If low, then you got a project to figure out where.  Good Luck.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 9:39pm
I have also seen the oil pressure switch be the cause of low oil pressure as it was leaking through the switch.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 6:59am
Thanks to all.  I hope to get over there and check it out Saturday.  The T idea is a good one if I can find a metric T.  Darn metric stuff is still hard to find around here.  Jim
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 7:00pm
Are you sure its metric?  Many metric tractors and engines still use SAE NPT and JIC fittings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2010 at 7:39pm
I had a kubota, that would act like you describe, I would put a mechanical gauge on it, as the other poster said. If that confirms drop in pressure, try dropping the oil pan, and take the suction tube off of the pump at the joint. There is an o-ring that got hard, and cracked, when the oil got thin enough it would suck air.  That model was a 2 cyl, L185, if I remember the # right.
This page was generated in 0.391 seconds.
