Allis Chalmers Fire Pump
bones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bones Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers Fire Pump
    Posted: 26 Sep 2013 at 1:12pm
Found an all brass sign/plaque with stand at sale. Any info as to age ect will be appreciated. Can supply photo if anyone is interested. thanks bones
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2013 at 8:38pm
absolutely provide a pic. I used to work on them and some of the info on the plate tells exactly what it is. is it just the plaque or the whole pump. they were very good pumps and easy to work on and parts are still available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bones Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2013 at 3:59pm
It is just the plaque. All brass and appears very old.New to this forum. I havn't figured out how to attach a pic. thanks ron
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2013 at 5:36am
I attended an NFPA Fire Safety Congress in Denver, CO in 2000.
'AC Pump' had a large display of 'Fire Engine Red' Fire Pumps.
I believe they are still in business, but under a different name.
Gary
Link to AC Fire Pump on ebay:
http://www.ebay.com/itm/ITT-AC-PUMP-MODEL-100-12X10X14-/261227192049?pt=LH_DefaultDomain_0&hash=item3cd25a9ef1
Edited by Gary - 28 Sep 2013 at 5:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2013 at 6:17am
ITT Pump has the AC line of pumps, Siemens has the AC line of electric motors and generation equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bones Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2013 at 4:41pm
I only have the plaque.When did AC use a plaque like this? How old is this plaque? Where was the pump used,fire house or building fire suspressant system? There is a photo in on file on this sight.Plaque reads Allis Chalmers Centrifugal Fire Pump
                  Capacities
1000 GPM against 65 lbs pressure of 4 good 11/2 inch smooth nozzle
   fire stream
dia of impeller 125/8inch full speed 1750 nrpm never fail to have ample power to operate pump at full capacity Plaque weighs approx. 20 lb solid brass
