Need parts for HD6E
Billoh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billoh Quote  Post ReplyReply Direct Link To This Post Topic: Need parts for HD6E
    Posted: 05 Feb 2010 at 2:15pm
I have a friend who needs tracks or rails for a HD6E.It has 37 links.Anybody know of any new or used?Thanks  Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 9:21am
 Look up BERCO and find dealer in your area. Track should still be made for the machine. Ifound a used set with good rail height and had new pins and bushings put into rails.
 Should be some equipment dealers in your area that do track work and this is first place to look .
 Can try Thill Track and Tractor in Eau Claire WI , they have been a source for many AC parts for me . They might locate a set close to you so shipping would be from where they are to you, or they might find a set local for you.
Edited by Coke-in-MN - 06 Feb 2010 at 9:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billoh Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 6:32pm
Thanks Coke for your input.That will give me something to work with. Bill
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2010 at 6:15am
i had an e-mail conversation with a berco rep, he said they have not made those tracks in 5-6 years. however, he did have a solution to take another model of track, same pitch but different grouser bolt hole and slightly wider that would work. he told me that i would have to buy new tracks (rails and grousers) and new rollers to accomadate the new size. i did not ask about pins and bushings for replacement. this update will ensure tracks for the future also. do not have the contact info as i erased the e-mail like a dummy.  berco is easily found on a search. hope this helps.
BobsAc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobsAc Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2010 at 6:58pm
I've got a new set and a good used set.... Bob S.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 3:57am
are they 37 links? what are you looking to get for either?
This page was generated in 0.085 seconds.
