hd4 torqe convertor Gauge
blackbirdstud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blackbirdstud Quote  Post ReplyReply Direct Link To This Post Topic: hd4 torqe convertor Gauge
    Posted: 07 Aug 2013 at 7:02pm
I have a HD4 dozer, the gauge itself, the paper backing inside the gauge has gonwe bad and its sealed so I fugured I would pull the dash and replace it. but the thermal wire that leads to the torqe convertor line is crimped to the back of the  gaude.. so I traced it back to the line and it looks liek either a half inch or 3/4 fitting into the line. So my question  is if I buy another TEMP gauge will it have those fitting or wil I have to cut my line and crimp it to another gauge soem how??
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2013 at 9:31pm
  Not sure but a replacement gauge should fit, possibly with just a pipe bushing to adapt. You can't cut the bourdon tube to the gauge, if that's what you were planning. I assume you are talking about the temp gauge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2013 at 9:32pm
Add to that, I think most automotive temp gauges have a 1/2 NTP fitting
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2013 at 1:16pm
The gauge is a full unit, from the bulb at the end to the gauge itself . It all needs to be replaced as a unit - sensing bulb and gage itself.
