Shocking low fuel use |
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35696 |
Topic: Shocking low fuel usePosted: 02 Aug 2013 at 2:42pm |
The old 7G I still have running seems to not like fuel very much or the fact the trans slips and lets the engine off the hook for load may be the cause.
Been removing a old fence line and terrace lip, years ago the field was around 60-70 feet wider but MO State Hwy Dept wanted to take a square corner out to a round curve and bought easement off the previous owners. They in turn moved the fence back to a old terrace line and let the hwy dept use the area I am now using for a entrance as a borrow area to raise the road bed. The fence line was rotten, wire strands just broke as I put any pressure on them to roll them up and the old wooden post just melted away at grade. So far I have moved around 25 yards of material, smoothed off around 110 feet of terrace curb, removed at least a dozen small trees and started on re-grading the entry. Old girl has only used 30-35 gallon fuel, about 10 full hours of operation over three days. Don't know of a Cat comparable. |
HD6 Merv
Joined: 03 Aug 2010 Location: New Zealand Points: 501 |
Posted: 02 Aug 2013 at 4:01pm |
Hi Dave
well first us southern hemisphere fellas had to convert that to litres; which is about 135L so that's 13.5 l/hr over 10 hrs. which I would thinks somewhere about normal. For comparison from my own experience with these 4 machines, working hard they,ll drink. Gear drive D4D 11L/hr powershift D4E and 941 trax 20L/hr HD6EP 15L/hr Your should get a idea of how hard yours was working by her engine note. Also being flat shoes should slip tracks quite easily esp if abit slippery. Check for trans slipping is very easy; as driveshaft universal joint should lock up at TC stall. ie If tracks have stopped moving driveshaft MUST lock up in any gear. Driveshaft turning but tracks stationery in any gear means transmission [or steering clutchs] slipping. AC will use less fuel than any comparable cat. Because AC were direct injection and cat. pre combustion chamber. Although from my own experience, is not a big difference between a pc and di cat engine;in my 2 D6Ds. Glad you got to push some dirt
tits tyres and tracks
they all cost you money |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42272 |
Posted: 02 Aug 2013 at 4:11pm |
I know my HD5 with the 2-71 Detroit used a lot less fuel (2 to 3 GPH) than the HD4 with the 2200 engine . Then the D6-9U I had was a thirsty beast - but my FD5 could outwork it and is easy on fuel compared.
Torque converter machines do have slippage I know the Perkins in the 715B also was easy on fuel as was the Perkins in the N/H 785 skid steer.
Posted: 02 Aug 2013 at 5:01pm |
Was more then once I started to shave with the bucket just slightly down angle so the teeth would start in before the edge then just ease into the berm and slowly roll the bucket back and up. New single lever is a horse to swing and curl but does work easier than two handles. I had a couple of bucket loads that tried to sit the nose on the ground but the machine did fine. Old multi-purpose is one heavy monster with full dirt load it is a load. Will get photos later, had to run as rain set in and I barely got the tarps on the tractor to sit it out.
I am working up to a MODOT project at this entrance to our place, they issued me a permit to shave the NE edge of the south entry for better visibility. The entry is on a corner, atop a shallow hill and traffic supposed to be at 35 or less isn't, can be scary to hair raising. School buses are the worst! Will show that off as I get there, figures to around 30 yards material to come out to a 3 or 4-1 back cut. |
Posted: 03 Aug 2013 at 7:10am |
This is the entry area and the old gap fence I am eliminating.
Where the gooseneck was parked in the second photo will get sloped from fence line down to road ditch, almost 4 feet down at far end to right at ditch. Just hope I don't hit rock too soon! |
Posted: 05 Aug 2013 at 5:13pm |
Got my dirt move complete, now have to wait and see if meets MODOT expectations.
All seeded and strawed since these were taken. Three days around 45 gallons fuel and a little trans oil(developed a new leak). Used the 180 and a drag blade for final grade after discing. |
Posted: 05 Aug 2013 at 5:19pm |
Would've gone more around the corner but hit a rock shelf, decided to bank off the last bit of grade and avoid it. Added a easy 100 feet of sight line to the entry. Will be re-establishing a fence line along the graded section where a old terrace berm had overgrown and raised over the years as the field lines drifted down.
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 06 Aug 2013 at 6:27am |
I hope you got at least a THANK YOU from the highway department for a job well done. Are you going to install the transmission from the doner machine? Keep us informed.
Posted: 06 Aug 2013 at 7:46am |
Will have to at least try the donor trans. My current unit slips really bad(driveshaft turns when sitting still) in low reverse and high forward, the low forward will slip intermittently so I suspect seals for the clutches are leaking by as well the packs themselves shot. I can swap them and see how it works, can only be a loss if it doesn't do anything. I will still have the original from this tractor to tear into and try to reseal and re-clutch.
Minnpar has clutch plates, was told by a couple old hands that the shaft seals will probably be a 'similar' hydraulic cylinder shaft seal or pump seal while I may have to try to get clutch pack seals either made(if metal) or something along the lines of a hydraulics shop to come up with something again close if nylon or teflon. If the drums are shot then anybodys guess. |
Posted: 06 Aug 2013 at 7:51am |
Job did end up costing a little more than expected, ran a stob of a cedar thru the sidewall of my 180's left front tire, ruined it, actually got the rim when I did not catch it and ran it over rocks in the berm cut. Second, my old Ford spit a rear brake pad, rotor is against the caliper pistons right now, never ending maintenance.
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 06 Aug 2013 at 9:49am |
Pretty country. Anything that green would hurt our eyes out here in arid Colorado!
Allis Express participant |
doctorcorey
Joined: 17 Jul 2011 Location: S. KC Missouri Points: 589 |
Posted: 06 Aug 2013 at 9:51am |
Posted: 06 Aug 2013 at 9:54am |
Been out in your neck of NO woods a few times John, still pretty there too. We are actually around 3" shy of rain this season but our grasses and wood do not seem to mind.
Posted: 07 Aug 2013 at 4:02pm |
Well first of two new projects done, new brakes on the rear of the Ford, did buy the tires for the front of the 180 and have the rims on the way as I do know that both are iffy at best from four years ago.
Posted: 16 Aug 2013 at 7:30pm |
Well tires and wheels are on the 180, old rims are pretty bad at the bead area but I think can be salvaged for spares. Went up to look at the landscaping, grass has already popped up, probably the Rye, Fescue will come on later.
Moved the old girl back to the barn, had a few minor messy leaks, fixed the first on the 4/1 clam cylinder, did look at the right final as it has resumed seeping around the shaft to sprocket junction, had been having no recharge issues with the batteries, doesn't use much so just lived with it, checked and found no power to the studs on the generator, next project in line. Have input seal for trans and output for the converter coming, will be dropping the driveshaft next as still don't have the donor trans pulled yet. |
