whats the safe amount to mill a head |
mjbower
Silver Level Joined: 04 Oct 2009 Location: Michigan Points: 255 |
Posted: 03 Aug 2013 at 6:56am |
on a b with m&w sleeves and pistons.need to keep in mind this is a hand crank tractor.thanks for any input.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78711 |
.100 inch. Remember the original compression was about 5.7 to 1... You will only get to about 6.5 to 1 if your lucky. Wont ever be a "high compression " motor.
Dick L
Up to .200 can be taken off without a problem. That is the most that I have removed on several heads. For some reason this picture will not show. http://images16.fotki.com/v301/photos/6/34676/7550174/Picture2027-vi.jpg?1375576752 I determined how much I could remove when building my pulling engines by sawing a head and boring into the firing chamber. This took all the opinions and myths out of what can or can not be done. Edited by Dick L - 03 Aug 2013 at 7:13pm |
THE-MAN
Silver Level Joined: 11 Mar 2013 Location: By the lake Points: 156 |
Remember to take a stone on a die grinder and chamfer ( round ) The crap out of the edge of the combustion chamber. You don't want any sharp edges.
volfan
Bronze Level Joined: 01 Aug 2013 Points: 25 |
I do not know if the diferences in head stud loctation or any other issues would.make it not interchange but the 149 head has no combustion chamber and is flat.it would up the compression if it will inerchange.
THE-MAN
That's very true Pank. I do have a flat head for sale is anyone is interested.
Dick L
They will not interchange but if they would then you need to figure out how do you would keep the valves from contacting the pistons . |
SF 49ers Fan
Silver Level Joined: 18 Jun 2013 Location: Iron Hills ME Points: 147 |
LEE??? OK, LOL that's cute.
XXXOOO's Edited by SF 49ers Fan - 04 Aug 2013 at 11:12am |
Dick, its been a year or so since i did the "figuring", but it thought about .150 inch and the valves "might" touch the piston tops, so i stopped at .100 ... Did you cut into the pistons for valve clearance, or is the clearance really over .200 ?
SF 49ers Fan
mjbower
thanks everybody i think ill stick with .100 off from it to play it safe.
Dick L
I took .200 off with no problems. |
Ken(MI)
Orange Level Joined: 14 Sep 2009 Location: Lansing, MI Points: 618 |
Mike, if you want to take it to the limit, let me know and you can borrow my sonic thickness tester. Hope to see you in Mulliken tomorrow. Ken
