switchin tranny
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Topic: switchin tranny
    Posted: 01 Feb 2010 at 1:34pm
I have bought a WD45 with a tranny that jumps out of 1st and 3rd, it has the curved shifter. I have a WD with a good tranny and straight shifter. I was wondering if these are the same and can be swaped. I see the tranny and rear appears to be 1 unit. Do I switch the whole thing? Will the WD trannry and rear hold up to WD45 HP? Thanks Todd
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 3:48pm
Todd, Yes you can change the trans and rear end unit out of your WD into the WD45 tractor as a unit. And Yes the WD trans and rear end will take the HP of the WD45.
With that said I'd just change the engine out of the WD45 into the WD, But that is just the way I'd do it. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 4:53pm
Either way will work ok.Pick the best of both and "marry" them.The 45 will have a 3 plate hand clutch VS 2 plate in WD (unless someone changed it).Not much work to swap clutches once trans is out of torque tube.
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 5:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 5:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 5:08pm
Mid 1954 was when they put 3 plate hand clutches in WD-45s.
This page was generated in 0.111 seconds.
