Couple items for sale
ChuckLuedtkeSEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Couple items for sale
    Posted: 30 Jan 2010 at 2:37pm
I need to raise some funds for possibly another tractor baby to come home, so I'm looking at getting rid of some things.
L59 Woods mower w/ mounting brackets and hand lift for a Allis Chalmers B.  Bought this last summer with a B.  My dad got the B, I got the mower.  Mower works good, but is missing the belt guards on it and I haven't mounted it to my B since I took it off of my dad's B.  Got all of the mounting brackets and pulley for the pto, and a pile of extra blades and I think an extra belt or two for it.  $350
One matched set of Hood ?offbrand 13.6 x 28" tires on power adjust rims and wheel centers.  Tires are in good shape, probably about 70% tread, look road worn, would make a good set for pulling.  Some minor dry cracking here and there.  Both hold air fine and have no fluid in them, although was in there at one time cause when you move one of the tires around, you can here a little fluid moving around that is left in it.  Little to no rust on the rims, valve stem holes good.  Only thing is rims and poweradjust centers are all painted white.  $350
80R sickle mower in great working shape.   Fair original paint with some decals on it.  Has one sickle missing but I have a whole box of sickles for it.  Have mounting bracket for WD/WD45 with it.  Works great, just haven't used it much in the last year or two.
A set of markers for a two row corn planter $100
1 power adjust rim in great shape 10 x 28 $100
1 power adjust rim in good shape, 10 x 28 w/ Firestone Field and Road 13.6 x 28 tire on it, needs valve stem hole rebuilt, tire has fluid in it $150
WD tractor, got it running good now.  Have gas tank off right now in the process of cleaning and relining it.  Good sheet metal.  Rear fenders have normal rust out spots behind fender stiffeners and a couple cracks but fairly straight.  good seat and steering wheel.  Took off magneto and put on distributor.   Replaced front crank seal, rear seal weeps a little.  Engine clutch and hand clutch good.  Rear tires are ok, one is like new but some drycracking, other tire is worn and drycracked.  Front tires are ok, and hold air but nothing special.  Needs to be rewired, haven't checked the generator yet.   Woudl be a good project for someone.  Good oil pressure, new radiator hoses when I put on front crank seal.  Also have a two bottom pin hitch plow for it in good shape with coulters, that I may consider selling with it, or seperate.  Haven't thought of a price yet.
I have pictures or can take pictures of anything that I listed.  I got a newer computer at Christmas so I dont have all the pictures on this computer.  If interested in anything, email or PM me or call me at 262-339-9364.  I will be going down to OH in early March and if you're on the way, I can bring things along for some minor gas money as I'm going that way anyways with probably an empty trailer.
Edited by ChuckLuedtkeSEWI - 30 Jan 2010 at 2:41pm
This page was generated in 0.107 seconds.
