combine engine
Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karl Quote  Post ReplyReply Direct Link To This Post Topic: combine engine
    Posted: 09 May 2013 at 9:27pm
hello everyone. What model of combine did the 301 diesel with the in line simms pump used in. And about what year?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2013 at 9:34pm
1972 and 1973 model "L".
Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karl Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2013 at 10:09pm
ok Thanks for the info
Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karl Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2013 at 10:56am
How about the M model combine ? did that have a "simms" pump also.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2013 at 11:30pm
dad thinks the 73 M 130 hp version (opposed to the 120 hp standard) may have had the simms.
I dont think the simms made it past 73, but it may have.
Dr. Allis is spot on on the L's.
we have one 73 L hydro with the simms that actually starts ok, otherwise they dont seem to start as well as the Roosa's
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2013 at 11:26am
I have a 3500 MK II industrial engine with a Simms (Minimec) pump and.048 injector tips.
Best I can figure it is the 224 HP setup. Added an intercooler and put it in my 220.
Dynos 190Hp without touching the settings. Starts like a new modern tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2013 at 5:31pm
if anyone is looking for a simms powered 301, we have one that ran when parked, may have a few more, just need to check what the parts combines have in them. one for sure in NW KS.
did the construction equipment use the simms more than the roosa? it seems the farm equipment didnt use the roosa very much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2013 at 6:28pm
Farm equipment almost exclusively used RoosaMaster pumps! Simms in-line was the odd-ball on Farm equipment and never on an AC tractor and only 1972 and 73 Gleaner combines, maybe a 74 model, but I've never seen one. Out of all the hundreds of Gleaner combines I've worked on since 1975, I can only remember seeing THREE of those orphan 301/Simms engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2013 at 6:50pm
Dr. Allis, what all construction equipment used the 301 with simms?
we have 2 out here, and 3 or so in idaho of the 301 simms engines in combines.
trying to keep a few of those running though.
Edited by GM Guy - 02 Jul 2013 at 6:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2013 at 8:12pm
Wheel loaders I have seen with 301/Simms.....maybe a 545 or 645 size.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2013 at 8:42pm
Yep, 545 and 605 wheeled loaders.
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2013 at 10:29pm
A local contractor has a 605B loader which came with the Simms pump.  The engine went on it, so he installed an M engine.  Now they call it "the jackrabbit"- the acceleration characteristics are quite different, and it is harder to maintain a constant speed- the roosa master seems to be more sensitive than the inline pump.
This page was generated in 0.227 seconds.
